Question about Rio Carbon MP3 Player
What to do when your mp layer gets wet alot? - Rio Carbon MP3 Player
    President:
  • 2,777 Answers
Do not attempt to use it for at least a day. Put it somewhere warm and dry, but not in direct sunlight. Let it dry out for as long as you possibly can. Once it's completely dried out there is a chance it will still work.
Posted on Jun 25, 2009
Gmail com login
my email destabezualem@gmail.com alwayes some people flow me i am understand long time every day wetness layer Ilive alon way lock door i have one bed room every day laer wetness way flow me alot of people sepch i am good what about tokon people every body play games my life?langch problem
Jan 05, 2014 | Computers & Internet
How do you get the Ranger Boat decal made by 3M Install on a window. The back plastic layer does not release the decal to the front paper layer? Sticker # RB911. Mar/sil
Even though I don't think this is the correct venue for your question, I'll take a stab at the answer.
Most decals I've ever seen are water activated. Wet them thoroughly, place against the glass, and the back will separate and can be removed.
May 08, 2011 | Chevrolet Silverado 1500HD Cars & Trucks
Lens is stuck shutter is open, changed batteries , tried new batteries, inserted SD card, installed AV lead, put some lubricating oil around lens layers, Any other ideas... Please N.
Do not put any oil into the set as you can get it worse.The only possibility is the failure of controller unit of the camera.The motor drives are not working , canbe not signal from the mP.
You will need to get this checked at the Samsung service centre for estimation.
Sep 30, 2010 | Samsung Digimax S800 Digital Camera
Remote buttons won't work except the power button.
open the case from the remote, you just need to clean the surface of the remote (the layer of carbon) of such dirt and dust etc.. way is: clean the layer with a dry cloth (can get a little wet). Do not forget to clean, the rubber from the remote buttons. Hopefully it can help you..
Aug 23, 2010 | One For All URC4220 Remote Control
2003 Ford F150 Regular Cab passenger side floor board wet at time
prob. the heater core located under the dash the lines go thru the firewall to the engine. on a '98 you gotta take alot of stuff off to get to it air bag, dash etc. alot of time but the parts arent too much $$
Feb 04, 2010 | 2003 Ford F150 Regular Cab
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Logitech Quickcam Orbit MP
It could be one of three things:
Is it making the noise, but not turning, or no noise at all? If it's making noise, but not following, then the gears have stripped (a common problem if you have used that feature alot)
Also, are you using the current software from Logitech's site?
And finally... are you turning on the feature to follow you (i believe its a different setting than the face tracking on the MP). Just poke around the menus, and you're bound to find it. I know it's definitely NOT turned on by default.
Dec 15, 2007 | Logitech QuickCam Orbit MP 961422-0403...
Text in CS2
Dear Roan,
It may be because your text is behind the background. That's what was happening to lots of people trying to use Photoshop CS2. Try going to Layer--then Arrange--then bring text to front.
This has worked for most of the people has fixed the problem. Hope thats helpful. If you still have problems you can go read the forums and also can access the help file in software's Help menu.
Nov 23, 2007 | Adobe Photoshop 7.0 for PC
SD Card
Mine works with 2GB card... AFAIK, that's the max, although I haven't tried a 4GB card.
I found updated firmware at:
http://uiss.max.io/
*update*  site has not been updated and download links not working... useful info there nonetheless... I will put the file(s) on my site:
http://french.moren.ca/rave-mp/Rave-MP-Install.zip
http://french.moren.ca/rave-mp/iLO256Manual.pdf
expect them up there by Oct. 20/07...
the ILO player referred to there is electronically identical, if not physical and the update works with all the Rave MP AMP series. I had a hard time finding this but it was worth the effort.
works great :-)
Sep 05, 2007 | GoVideo Rave-MP AMP512 MP3 Player
Rio Carbon MP3 Player Logo
207 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
