Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Just snow when using the hdmi
I bought a philips dvp3960 upconvert player and hooked it up thru the hdmi and as it loads i get a picture but it flickers. once it loads all i get is snow. also the hdmi resolution option on the player stays greyed out. i tried it on my brothers tv and had no problems.
  • 138 Answers
Re: just snow when using the hdmi
Ih the DVP works on the other set and not this one the proble is the snall signal board 313503711711.
Posted on Aug 19, 2008
0 characters
3 Points
I have been trying to hook my dvd player up to my WD-52528 mitsubishi,but i am having touble trying to figure it out so i can watch a movie,and i have misplaced my manuel.can anybody help me?
If you have an upconvert dvd player use a hdmi cable, it's the easiest. If not use component cables for video (red green and blue, labeled Y, pb, pr on the back of the tv) and standard left & right ( red and white) for audio.
Aug 06, 2009 | Projection Televisions
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Jun 11, 2008 | Projection Televisions
well are using hdmi cables u must get hd box and upconverting dvd player with hdmi cables set britness 50 contrast 65 coler 40 but get hd soreses use hdmi cables
Mar 15, 2008 | Projection Televisions
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
Just Google hdmi to component....You'll find plenty of choices.
Jan 10, 2008 | Pioneer PRO-710HD 64" Rear Projection...
No picture on my hitachi 57f500 when i connect hdmi to dvi from new dvd Player
If you have a 2006 or later model, you must set up Blue Ray DVD to Auto Mode on their output setting.
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
