Question about Sony Playstation 3 (PS3) Console
Ps3 recently displaying 80029906 lights - Sony Playstation 3 (PS3) Console
  • 3 Answers
I know! just stick your P.E.N.I.S. in the disk tray, close it, then once the pain becomes unbearable (1 to 2 minutes) open it, C.U.M. in a glass, drink it, then your problem will be solved. its amazing that this actually works, but it does!
Posted on Jun 25, 2009
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation┬«3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
After the recent ps3 update, the tv icon is missing from the xmb. I understand it could be a firmware issue but also think it could be linked to the fact that i cannot watch videos on youtube above 240p...
The most recent update to the PS3 firmware changed the TV icon to TV/Video Services. If you are not connected through component cables or HDMI cables, your PS3 will not display anything above 240p. One solution might be to check for updates again, or connect through HDMI.
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
Ho una playstation 3, dopo 15 minuti che vedo il film in blu-ray si blocca con errore 80029941-80029906, se rimetto un dvd normale lo legge. cosa devo fare?
Da tua PS molto probabilmente puo essere un errore di lettore bluray. Il lettore e fatto da due lente, una che legge il bluray, altra- il dvd. Comunque, si deve da cambiare tutta la sistema di lente, perche nn si cambia una lente aparte. Da solito costa 120 euro lavoro compreso.
May 28, 2011 | Sony Playstation 3 (PS3) Console
Ps3 screen margins too wide for tv display
Try holding your power button on your ps3 down till it blinks.(not your main power switch on back of console) I do believe if correct, this should reset your ps3 resolution to an auto set for best display on your tv. It may pop up with a message on resolution, but that should work. I had similar problems and that worked for me.
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
YM ps3 doesnt display anything
Put your PS3 in standby mode (hold the power button until the light turns red) then release, and hold the power button again for about 10 seconds, or until the light beeps a second time. When the PS3 restarts, it should display using whatever it finds first.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 HDMI connection issues
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Hdmi on my sony PS3 not working
Have you changed your HDMI settings recently? Make sure you are using the correct resolution supported by your HDTV. The audio settings can be changed independently to the display.
You can reset the display settings by turning off the PS3 and holding down the power button down for 10 seconds.
Jul 14, 2009 | Sony PlayStation® 3 (60 GB) Console
Bought a new ps3 all i get is blue screen
Are you running your HDMI from the PS3 directly to your display or through a tuner first?
May 23, 2009 | Sony Playstation 3 (PS3) Console
PS3 PAL HDMI video problem with a HDTV SAMSUNG SQ01
hmmm maybe your tv should be set to a different setting other than PAL
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Error 80029906 and error 80029941 on playstation 3
I had similar problems with my console. I could play DVDs fine. Games would start, usually, and then freeze. Blue ray movies would give me the 80029906 error.
I tried every fix I could find on the Internet, but nothing helped. My system is no longer under warrantee, and spending $148 to get a refurb back from Sony, regardless of the actual issue, bothered me to no end.
I finally found a company, videogame911.com, which specializes in game system repair. Basically, I went to their website and created a service request, then shipped my PS3 to them (3 days with UPS Ground). The same day they received it, I got an update from them with their inspection results (bad blu-ray player) and an estimate for repair and return shipping costs. The repair and return shipping were $154. I authorized the repair and paid online, and they had my console fixed and shipped back the next day.
The whole process took about a week to complete, my console is working like a champ, and most importantly, I got MY console back.
Granted, the cost was a couple of bucks higher then what Sony would have charged me. However, given that the problem could have been something else, such as a dirty lens or something, there was a good possibility that the actual repairs could have been cheaper. And, unlike with Sony, I didn't loose a single file off of my hard drive.
Hope that helps.
Jul 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
317 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
