Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
My pump works for a little while then it stops for no reason. We can't get to start, it is hot. A few hours later, it will start again but only for a couple of hours.
    President:
  • Intex Master
  • 1,378 Answers
Something is causing it to overheat; the shut off is automatic and is saving the pump from burning up. The pump may be failing or there is something overloading it causing the heat.
Try to make sure it is clean and free of any blockages not allowing air to flow around it.
Otherwise, plan on a new pump soon.
Posted on Jun 26, 2009
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Engine shuts off while car is driving. Still have all electrical. Try to restart car and motor will turn over but not crank. Try to restart car a few hours later and car starts and runs for about 10...
Many times a problem like yours can be traced to a failing fuel pump. When it gets hot it binds and stops, later after it cools off it functions normally 'till it gets hot again. Next time is dies, immediately turn the key off, then to the run position and listen for the pump (humming in tank) if you don't hear it, likely that's the problem. Never buy parts without testing though. A pump alone can set you back over $200.!!!
Apr 18, 2011 | 2003 Jeep Grand Cherokee
Pump works for about 20 seconds then stops for 40 seconds then starts again.
this sounds as if motor is overheating and the thermal switch is stopping it (why it restarts by itself) if a pump is overheating then a few reasons need be looked at , is pump encountering higher viscosity's than designed for and is having trouble moving liquid fast enough , is distance pump has to lift liquid over what it's designed to do most of these pumps use liquid it's moving to provide cooling to pump , is liquid it's moving warm/Hot allready if so use different type of pump (non submerged) and last but not least is pump worn out and is failing moving parts wearing together make heat !!! ?
Jun 27, 2010 | Little Giant Submersible Fountain Pump
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
I bought 6 cans of aerosol spray tanner they spray for a few secs
put them in hot water and shake them for a good 2 minute and then spray with can upside down for a few seconds. This sometime cleans the spray tube. Make sure tip is clean.. try again..If still not working then dispose safely according to local laws.
Mar 16, 2010 | Air Tools & Compressors
My well pump starts and stops
look up the info on the motor, it could be a start/run capacitor. low voltage will cause the pump to run hot. You really need to make sure the wiring is good and sixed correctly and the capcitor is ok
Aug 30, 2009 | Jandy In-Ground Plus HP Pump
My 2000 ford contour just yesterday started getting sluggish, eas having problems getting past 50 miles per hour.like when you pull something with your truck up hill.. then today we drove it to town this...
First try changing the fuel filter. It is extremely easy and costs about 12 dollars at Wal-mart. If that doesn't work than try changing the fuel pump itself. Little more costly but still pretty simple to do.
Aug 08, 2008 | 2000 Ford Contour
Won't stop pumping
H android1968 and danimaldds
The reason it keeps running is because there is water in the pan under the dishwasher. firs this to do is shut the power off, then take the kick plate off, remove all the water that you can. this should fix it , if it happens again there might be a leak from a seal or from suds. hope this helps
brent
Jul 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
478 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
