Need a parts diagram to find the name of the problem part
SOURCE: xerox phaser 8400
Replacing the pring head.
1. Remove the side covers.
2. Remove the ink loader assembly. There are 2 connectors on the ink loader. SO remove it slowly.
3. Remove the spring guides on the print head. One on each side, Held in my one torx screw.
4. Remove the spring bracked assembly on the left side of the printer, it puts pressure on the XY axis motor to position the print head. Just pop it off and position it up and to the left of the bracket.
5. Remove the steel square block on the left bottom side of the frame.
6. Unplug the harness and ribbon cables and then from the back of the printer, remove the print head, be careful not to hit the drum.
Install the print head, the ribbon cables are somewhat difficult to plug back in, Just be patient. and make sure they are conneted firmly. Also when replacing the cables and harness, be sure they are routed corectly so the print head does not get bound on them.
Set the print head into position and install the steel block, then the spring bracket on the XY motor, then the spring brackets in the proper positions. Dont forget to put that spring bracket back on, It is easy to over look.
Make sure all things are plugged in on the print head.
Next reinstall the ink loader, make sure all connectors are connected.
Install the covers and you are done.
Take your time, probably should take about an hour. Just to it carefully and methodically.
SOURCE: Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
SOURCE: xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
SOURCE: need xerox phaser 3124 printer driver compatible for mac 10.6
go to www.samsung.com download and install mac driver for ML-2510 works like a charm for xerox phaser 3124
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve
imaging unit recognition problems, link below.
http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
Usually this problem only occurs if the NVRAM has been reset or the engine
board has been replaced without backing up the NVRAM.
You can download the snippet to your printer through Centreware or by
downloading the 'File Downloader' utility from the same page above.
Hope this helps.
