Question about Brother P-Touch 1180 Label Printer
Model #2300/2310- After I select a font size and I go to print the label, it asks me Character Size Auto? How do I respond No? I want it to print at the size I selected. But it does not lock the size I selected in.
SOURCE: labeler #1950
If your Size (Code 2) is on Auto you can't change the Font
Posted on Jul 22, 2008
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
erickg
  • 116 Answers
SOURCE: Unable to change font size
need to hit enter after changing it.
Posted on Apr 28, 2009
Jimsta01
  • 405 Answers
SOURCE: how do i change the font size on my label maker?
Please follow the link below for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000247/pt1180ug01caen.pdf
Posted on Mar 30, 2010
d-ruffles
  • 65 Answers
SOURCE: How do I change the font size on my lavel maker
If you go into the menu, and you go down to font, hit enter. It should bring up size, style etc. If not, please tell me.
Posted on May 11, 2010
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Brother p-touch model 1880 label maker- how do you change the font size
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
I have a LabelMaker 450D and I do not know how to make the font a smaller size. I want to print a label that has a name in a larger size and a line underneath with the job title that is in a smaller size...
Hello. Here is a free downloadable manual for your labelmaker. http://www.dymo.com/media/UserGuides/LM450D_US_931764.pdf
Turn to pages 9-12 to learn how to change fonts and how to do multiple fonts and underlining all at once.
The label maker remembers the last feature
selection made so that each time you enter one of the
feature menus described in this section, you are
positioned at the last item selected from that menu. J.
Aug 07, 2010 | Office Equipment & Supplies
I can't figure out how to make the font size larger
Try this solution to change the font size:
1. SIZE1 equals Standard Size.
2. SIZE2 equals Double Width.
3. SIZE3 equals Double Height.
4. SIZE4 equals Double Width & Double Height.
5. SIZE5 equals 4 x Width & Double Height.
6. AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Hope this helps.
Aug 04, 2010 | Brother P-Touch 1180 Label Printer
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
Can't change the font style & size on my Brother PT-65 Label make
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Problem with printed character size on Samsung CLP 300
It sounds like your drivers are bad reinstall the printer.
Dec 18, 2008 | Samsung CLP 300 Laser Printer
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Labeler #1950
Press "Line Out" to remove return character, It thinks you want to print on more than one line so is making font smaller to fit. Good luck.
Jan 21, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 1180 Label Printer Logo
104 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
