Question about Filter Queen Vacuums
Motor arcing when vacuum is turned on. - Filter Queen Vacuums
  • 50 Answers
Motor brushes have gone bad.On some vacumcleaners they can be replaced some need motor replacement
Posted on Jun 26, 2009
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
Brushes in motor are arcing badly and motor only occasionally will start. How do i remove the motor brushes for replacement. (from the green plastic case)
This is kinda of tricky. need to know what kinda of vacuum it is first. However if you get it apart. To fix this problem the armeture brass needs to be cleaned & you should replace both carbon brushes. Should be cheap to fix if you are up to it. good luck save some $$$$...
Nov 10, 2009 | Vacuums
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vac quit working
I have a Bissell powerforce bagless 12 ampsthe brush will not turn, motor is working not sure if brush is gone or I need a new belt it shows spots of burns like the brush is jamed
Feb 23, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Burning Smell coming from the moter
This could be a motor problem. There is always a slight blue arcing that occurs when an electrical motor runs and can be visible through the exhaust vent, but any excessive arcing indicates a problem. If the carbon brushes are sticking, this will cause excessive arcing and can be corrected by an experience service person, but if there is any electrical failure, the motor would have to be replaced. There are no parts available for these motors and the expense of replacing an armature (the likely culprit) would be more than the motor. This could also be as simple as a worn belt, but usually, belts will not produce the smell your describing. When a motor is burning out, it will produce an acrid odor that will linger for a long time.
Feb 23, 2008 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Vacuums Logo
112 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
