Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer not working Canon MP390 All in One
Moved printer from room to room and now the computer doesn't recognize the printer, Uninstalled everything, reloaded everyting and connected USB to PC and front of MP390 and or USB to Back of MP390. Nothing, doesn't print.
Will copy in color.
Susan 408-859-9061
5 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Canon MP 530
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Nov 03, 2007
  • 16 Answers
SOURCE: printer not responding to the computer
I had a similar problem with a Multipass F30 - check that the Canon Service "mpservice" is running. In the situation I had it was set to automatic, but the service was stopped. You can locate the Services by going to the Control Panel, then Performance & Maintenance if you are using catagory view or directly to Administrative Tools if in Classic View. Double click on Administrative Tools and then open Services. Scroll down and locate mpservice to see if it is running. I hope this helps.
Posted on Jan 13, 2008
SOURCE: Canon MP780 issue on Mac OS/X
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Posted on Oct 04, 2008
  • 22 Answers
SOURCE: printer not printing color or black and white properly.
Dont do anything such stupid things go to authorised service center do will do the needful
Posted on Mar 05, 2009
  • 696 Answers
SOURCE: Whant to print wireless with my Canon MP390 printer
No this will not work as the printer has no way to install the dongle into it's operating system.
In order to make it wireless you will need either a wireless access point if the printer already has an ethernet port a wireless USB print server if not.
Look at model # PM111UW on for refernece.
Posted on May 28, 2009
0 characters
1 Points
This is driving me mad! I had a canon mp150 and the scanner stopped working! After a lot of messing around i thought i'd just buy another printer as i thought the problem might just be the mp150...
Download and install the latest driver for your printer from Canon. Install the driver first, connect the printer to the computer using a different USB port than you usually use for the printer, then restart your computer.
Feb 28, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Computer freezes when usb cable from printer is
ive try that before, there is a virus on your computer, that detects the updates of your USB port, try to scan your computer,
Aug 08, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
My computer is not recognizing my printer
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Jun 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How can i keep my canon mp390 from being so noisey?
Yeas ago we usede to put coardboard boxs over then to make it more quiet in the room.
Dec 15, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon mp390 printer & apple computers
printfab2 do software that supports your canon for printing, image capture should work for scans, until canon port their slick all in one software you will have to use separate programs.If you need help to load the software get back to me.
Dec 01, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon smartbase Mp 390 ##343 Check printer
can you help my printer canon smartbase mp390 not working gives notice check printer ##343
Jul 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
ahh..sorry..thought you might like it that way..anyway, the only way to do this is to remove the s/w that's in other language, and re install english language version
you can get that set here.
Mar 24, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Sofeware for canon muliPASS MP390
Here you can download drivers and software for mp390. Just select drivers and download tab, and select your OS (eg.Windows xp, Windows Vista etc.).
Mar 22, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
