Question about Bruder Cat Skid Steer Loader
What do you have to remove to get to the fuel tank on 863 bobcat
For remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Posted on Oct 05, 2009
3 Suggested Answers
SOURCE: I have a bobcat 863,
the fuel intake is from the top of the fuel tank, there is a tube which goes to the bottom of the tank. This tube may have deteriorated and come off or have a crack. You can lift the cab and reach down to the tank to pull the plug to check. good luck
Posted on Feb 06, 2011
  • 223 Answers
SOURCE: I have an 863 bobcat that doesn't idle well and
There should be more than just one filter on that motor, check at the lift pump and injector pump.
Gelled fuel can be a pain, if that's the problem then warm it up (tarp and salamander for a few hours or leave it inside the shop overnight if the shop is warm), top off the fuel and give it a can of Power Service brand Diesel Kleen, then try it.
lp
Posted on Dec 30, 2010
So I need some help. I have a 2012 bobcat 3450 Myanmar diesel. The fuel pick tube in the fuel tank is clogged. I want to remove it, clean it and reinstall it. ??? I had purchase a bobcat service manual for...
unlikely that it will be clogged
May be blocked by the build up of alge growth caused by condensation in the hot tank as it cools down
most pick up lines ar screwed in the top so disconnect ant hoses /lines to that point then unscrew it out
If you have a black slime like substance on the end , remove the tank and have it cleaned out with steam then use a diesel fuel conditioner to clean out the ,lines and pump
never allow the machine to sit with less than 3/4 tank of fuel to prevent a reoccurrence of the alge
Mar 16, 2018 | Cars & Trucks
Can I find out what year a Bobcat is by the serial number?
look here
http://www.bobcat.com/company-info/help-center/faq
Apr 03, 2017 | The Optics
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
What is the easiest way to remove the fuel tank in a bobcat 853
There is no easy way, other than removing engine as the tank is wedge shaped and lies under engine and battery.
In a pinch get a boat fuel tank and re route your fuel lines.
Dec 18, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
863 bobcat getting oil in fuel
Internal leak in lift pump. Leaks fuel into cam to oil pan.
Jun 21, 2012 | Bruder Cat Skid Steer Loader
I have a bobcat 863, turns over ok, but will not start. Did not run out of fuel.
Jan 27, 2011 | Bruder Cat Skid Steer Loader
I have an 863 bobcat that doesn't idle well and continues to quit running. I changed the fuel filter, put heat in tank and a little bit of diesel conditioner anti-gel.
lp
Dec 30, 2010 | Bruder Cat Skid Steer Loader
Replace fuel line on 863 bobcat
you need to take off thr right rear tire and remove inspection plate,then reach in and pull line from top of tank. if pickup tube is original eqip. it has probably broke off. you will find 3/4 of old tube in bottom of tank. go to bobcat dealer and get replacement tube,which is now all poly and flexible. while you are at it,reroute fuel line to the plunger,by putting it down bottom right side of engine,right under motor mount below alternator. an easy test of fuel line is to take off fuel cap and then blow air in hose at primer bulb towards tank.if you hear the air at fuel tank opening,your tube is broken. if you hear bubbling line should be good. you need to have a can of air in your tool kit,go to walmart and get can of air in the electronics department,the opening is small,get yourself an male air fitting from automotives and put on end of air can,use pipe tape on end. if fuel line gets dirty you can blow back to tank at primer bulb,this an emergency fix,if primer bulb is collapsed the line is clogged or pickup is clogged.
Jan 11, 2010 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
5,590 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
