Question about John Deere Gilmour Traveling Sprinkler - 4010j
John Deere 3520 Diesel tractor NO Start
No start, has fuel to pump not coming out to injectors. Dash says error 69. Has power and ground to fuel relay, power and ground to fuel filter, This is supose to be self priming no bleeding needed.
  • markqsn Jul 01, 2009
    Turned out to be fuel shut-off solenoid. I had fuel tp pump but not to injectors.Thanks for response.
  • Keith Parker May 11, 2010
    Hi..my name is Keith..did the tractor run out of fuel..or did it just not start oneday?
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
Replaced fuel filter on 2 cyl diesel on my skid loader, started great before , wont start now. Can manually pump to top of both injectors.
Fill the tank and all fuel filters with diesel... There should be one or two fuel pressure release valves on the fuel line, one after the pump and filter. If there's only one, losen it, and crank over engine, let all the air out of the system, and wait till there's only diesel, gushing out of the line, before you tighten up the valve. If there's 2... Open both and Start with the one farthest away from the injectors...when fuel comes close the farthest one first, then the other one.
Sep 22, 2013 | John Deere 420,1020,2010,2020,2510,2520...
2305 john deere want start replaced fuel pump still want start seems like no fire does diesle have fire
diesel work for compression ignition and have only glo plugs to help with starting in cold weather. You will need to bleed the air out of the pump and pressure lines to the injector. Crack the bleed screw on the pump until you get solid fuel then crack the injector line until it drips fuel. re tighten and it should go.
Jun 12, 2013 | John Deere Garden
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Gilmour  Traveling Sprinkler - 4010j Logo
269 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
