Question about Frigidaire 24" Single Gas Wall Oven with Built-In Full-Size Lower Broiler - Black
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time... but this time they only lasted a month. Now, the door looses tension about 2 inches from the closed position. I am going to order another set, but any idea what would cause this? The oven gets used 3 or 4 times a week at most.
  • brian215 Jun 25, 2009
    I don't see anything like what you described in the door... Here is the hinge I used (http://appliancehelp.com/Catalog_Detail....) and it appears to be self-contained. I see no wheel... the hinge just screws into the door and then slides into the oven. As a test, I took the hinges out and put them in the oven without the door... it looks like the springs are just too weak to keep the door up... but it felt perfectly fine for the first month. One of the hinges looks a little discolored... I wonder if the heat is weakening the hinges... or of these are just cheapt aftermarket hinges that are not built to last?
  • brian215 Jun 26, 2009
    They are supposed to be genuine OEM parts, but who knows in reality. Thank you for your help.
  • 25 Answers
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Posted on Jun 25, 2009
  • wildwest1959 Jun 25, 2009
    Ah, ok...my apology. I see the price in dollars, I thought it was a UK Whirlpool. Looking at the type of hinge you have, I would agree that the hinge itself is at fault. Are you getting supplied with genuine parts? Patent or copy parts can sometimes be a poor copy of the originals. Heat shouldn't really affect them too much as they are designed with that in mind. If they were genuine parts, you may have had a duff set...hope you get on ok with it. Good luck!
Door stays open about 2 inches
Replacing the hinges is risky because you need to be 100% sure the new hinges go back in the exact spot the old ones were.
Otherwise, there might be leakage, which can lead to arcing and possible fire.
The exploded view / parts list is here.
If the hinges are not secure, the door may slip, which can cause leakage or failure to operate correctly.
Also, there is a bulletin about these regarding the door locking _closed_ but maybe it's applicable in this case, too.
Here's the text of the bulletin:
KitchenAid & Whirlpool Electric Wall Ovens And Dual Fuel Range
MODELS: KEBC101K, KEBC107K, KEBC141K, KEBC147K, KEBC171K, KEBC177K, KEBC206K, KEBC207K, KEBC208K, KEBC247K, KEBC276K, KEBC277K, KEBC278K, YKEBC107K, YKEBC177K, YKEBC208K, YKEBC278K GBD277PD, GBD307PD, YGBD307PD, GMC275PD, GMC305PD, RBD245PD, RBD275PD, RBD276PD, RBD305PD, RBD306PD, RBD307PD, AND KDRP407HS
PRODUCTS BUILT BETWEEN CODE DATES: XP22 - XP29
CONCERN: Error Code "F5 E1" or "F5 E7" (door latch not unlocking the door after self-clean cycle).
CAUSE: This problem is caused by defective material in the core of the solenoid on the door latch. The solenoid works properly at normal temperatures, and at the beginning of a self-clean cycle. However, when heated, the plastic core binds the metal plunger, and will not allow it to unlock at the end of a cycle. Once cooled, the solenoid will again work properly. When a technician inspects the solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Jul 23, 2013 | Ovens
My KitchenAid Double Oven Model KEMC308SS0 has a door problem (I think). Both Doors swing down past the horizontal level. Doesnt look right and they both do not close all the way. Opened one iin the...
I have spent $$$ on new hinges for my KitchenAid double oven doors over the past few years, but they always fail after 6 months or so. Recently I decided on an elegantly simple solution. K&J Magnetics (kjmagnetics.com) carries a line of 1/8" thick, countersunk Neodymium magnets that are perfect. I purchased a pair of their # RE22CS-N magnets (3/4" dia X 1/8" thick), attached them to the upper corners of the door just outside the gasket area with some #8 flathead screws, and viola! They do a great job of closing the door while still allowing a proper gasket seal. Lighter or heavier doors might require a different magnet, but K&J offers types with varying pull-in forces, so you should find one to match.
Sign up for our Monthly Newsletter kjmagnetics.com
Magnetics Incredibly strong...
Dec 10, 2010 | KitchenAid Architect Series KEMC308KSS...
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Frigidaire 24" Single Gas Wall Oven with Built-In Full-Size Lower Broiler - Black Logo
303 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
