Question about Altusen MasterView CS1708 (0672792151026) 8-port KVM Switch
Reset username and password on MasterView CS1708 KVM Switch
Locked out, need to over ride admin password
If there is a switch next to the power port on the back pushing it for a few seconds should reset it to factory default.
Defaults: Username: admin Password: password
Mar 05, 2011 | Avocent SwitchView OSD 8-port KVM Switch
Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Dec 12, 2008 | Videk ATEN Master View 9834 KVM Switch
Lost login Username and Password
How do I use the reset the password on my DES-3226?
Nov 14, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Altusen MasterView CS1708 (0672792151026) 8-port KVM Switch Logo
1,180 people viewed this question
Top Altusen Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
