Question about Kitchen Appliances - Others
My automatic sliding gate will not close properly
The gate is powered by a Nice Robus motor and has started, intermittently, to ''bounce'' back when it gets to the closed position against the gate post. It`s as if the gate post itself is being recognized as an obstruction. I can´t find any manuals for Nice products to get any clues - can anyone help please?
    President:
  • 1,185 Answers
From your description it looks as if the auto detection system needs setting up again
Have a look at
http://www.proforme.co.uk/images/Robus600_1000_EN.pdf
Posted on Jun 25, 2009
  • anthonygorma Nov 26, 2010
    i found this page through internet explorer by adding key words witch brought me here its seems on faulse pretenses it wasnot in anyway helpfull???
Sliding gate pauses and shakes when it first starts, both opening and closing. Does this for a while, going very slow, then smooths out and closes and opens ok.
most sliding gates suffer form dirt, grass , rocks in the gate track so constant cleaning of that track is essential
small twigs , rocks will slide along with the wheels on opening but are an obstruction for the wheels on closing
most closing gates run a cog and rack system at the bottom ot the gate so check that the mesh of the rack and cog is correct at either end
Jul 26, 2016 | Cars & Trucks
My nice sliding gate only closes with the fob and will not open
There are several possible causes, but the first to check is the limit switches. When the gate opens, it is supposed to trip a limit switch that tells the mechanism that the gate is fully open. If the switch is not tripped, it will not respond properly to a command to close. It may think the gate is running into an obstruction and then just shuts down.
Feb 02, 2015 | Nice Robuskit Slide Gate Operator Motor...
Have a BFT Phobos BT gate opener. The problem I am having is my gate won't close all the way. There is a small gap. I tried to set the limit switch by removing the screw but it isn't...
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended.
You may have to re-position the gate opener.
Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
Feb 02, 2015 | BFT R93524500001 - Swing Gate Kit, Single,...
Are gate closers really effective & how it works?
Gate closer is a device, which consist of steel spring in a spiral shape fix on the door that close the door automatically without any human being intervention or electricity. http://www.gateshut.net/about-gate-closer.html
Jul 24, 2013 | Rixson Exterior Gate Closer With Sliding...
What is Spring Gate Closer and How it Close the door automatically?
It consist of hard steel or aluminum in spring shape, which force the gate to shut it close the door automatically without any electricity or heavy internal mechanism.http://www.gateshut.net/
Jun 07, 2013 | Rixson Exterior Gate Closer With Sliding...
Where can I find a wooden automatic gate?
A wooden driveway gate needs to be supplemented with a steel frame to last since they will be opened much more frequently than an ordinary wood gate. The slide type gates will need the structural strength to resist the pulling of the chain. A swing gate, will be cantilevered since a wheel at the opposite end will trigger the obstruction reversing mechanism in the gate operator. This cantilevering over the long width of a driveway requires steel in the structure both to prevent sagging and to keep the gate looking good over time. Gaps and misalignment will occur naturally as the wood shrinks and expands in weather. The steel frame helps to hold everything together tightly.
We make our gates using wood cladding over a steel frame. If you like check out our link at the bottom for more information. Here are some projects we have completed.
http://aaagate.com/wood-iron-gates
Jan 31, 2013 | Home Fencing
My elite gate won't close. the charge ok led light is not on. checked everything and it's ok. switch limit switch on both sides works fine except when trying to close, it won't run.
If you disengage the motor does the gate slide easily? if not that could be the problem, most gate control boards have a sensor that detects the current drawn by the motor, if the gate hits an obstruction or is jammed the motor draws more current and the sensor stops the gate moving. It could also be a problem with the safety sensor, to check this locate the safety sensor input on the control panel and bridge the 2 contacts if the gate then works the safety sensor is the problem.
Dec 28, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Gate will not completely close.
Most likely your chain is not going to be your problem. When you pull the cover off of your SL 3000 there will be a little rectangle box on top. There is either one or 2 screws holding the lid down...loosen the screws and take the lid off. Inside there will be a long screw drive with 2 plastic nuts with teeth.At either end of the screw drive you will find a switch that one of the nuts should be resting on. (these are your limit switches that tell the motor when to stop) Run the gate open and closed...when you run it closed see if it is hitting one of the limit switches when it stops. (turn off the power) If so, hold back the plate keeping the nut in place and move the nut further away from the limit switch.(don't move it too far so that you don't slam the gate too hard into the catch post and hurt the post/gate/motor) Turn the power back on and run it again. Repete this untill the gate is stopping where you would like it too. e-mail me with any further questions tgutierrez13@gmail.com
Jan 08, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Kitchen Appliances - Others Logo
473 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
