Question about Sony PlayStation® 3 (60 GB) Console
The power to my ps3 shuts off after a second of it being on
After the green a faint yellow light comes on for a millisecond then it shuts off and blinks red. I also have my game cod5 still in it so now I can't eject it. The first time it turned off was when I was playing cod5 for about 30-50 minutes then it just shut off on me. I called sony for a solution but it didn't work. they said to try plugging it into a different power outlet but nothing happened.
  • 3 Answers
Go on youtube and search for Gilksy. he has an option of not paying sony 150 bucks for a refurb unit. This does work if the problem is in the motherboard. follow his 6 videos and you should be ok if you do it right.
DO THIS AT YOUR OWN RISK. it may not work because the problem may not be in the motherboard. But if your out of warranty it wont hurt to try and if it fails you can still call sony and pay 150 for the refurb unit.
Posted on Jun 26, 2009
  • 21 Answers
The yellow light, from what I have read on the Playstation message boards, is a system failure. Although some have said it refers to the Playstation overheating, that is not what it means. Unfortunately, Sony will have to fix it for you or send you a new system as long as it is under warranty.
Posted on Jun 25, 2009
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
My PS3 turns on and then turns off 3 seconds later. my PS3 will not stay on for longer than 3 seconds.
I need to know what the lights on the front do. Do they flash? Before it shuts off do you see a yellow light? Green light?
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
313 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
