Question about DXG Technology DXG-503 Digital Camera
How Do I load Pictures to My Computer with this Camera?
Hi, I have a DXG Model 503, and I need to load Pictures to my Computer, and there are no directions. Can someone help me?
  • crabtreel Mar 09, 2009
    We've lost are book to our camera that had instructions to it. We have a HP computer and this type of camera. Are they compatible? Is there any way we can get instructions on how to get pictures off our camera?
I have the same camera... it's been a piece of crap since day one! I actually had to go and buy a disposable camera at a concert once because it continuously kept taking horrible, fuzzy pictures. The disposable took way better pictures! That's ridiculous! I read the manual cover to cover to see if i was just taking the pictures wrong or something...nope! the camera is just a worthless pile! I know that probably doesn't help at all, but i'm so frustrated with my camera cuz now it's frozen and doesn't do anything and i really don't have the money to go out and buy a digital camera at the moment. Oh well. what a **** product!
Posted on Feb 19, 2008
  • 556 Answers
These appear to the the manual link and the driver link from the website
Manual Link
Driver Link
Posted on Dec 16, 2007
Unable to download pictures from DXG 503 camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Mar 29, 2012 | DXG Technology DXG-503 Digital Camera
Turn timer off on my DXG -503 HELP
http://www.dxgusa.com/CustomerService/Manuals/DXG503.pdf is the instruction manual for the camera. Page 28 explains how to turn off the self timer. Hope this helps!
May 11, 2011 | DXG Technology DXG-503 Digital Camera
Dxg503 in camera mode shows memory full. view mode shows no file. When i try to download to computer it either does not show up or indicates that it is not accessible. using internal memory only
is there anything important in the internal memory? not many pictures can fit there so I suppose probably no?
Format the memory.
Use setup mode to set the camera configurations to suit your personal preferences. Turn the mode dial to SET Mode. And select "Format"
Use the format option to format the camera memory or memory card.
Note: When you format the memory, all data will be deleted.
Now take a few pictures and see if they show up in the view mode or if you are able to get them to the computer. Let me know how that turns out.
Feb 24, 2011 | DXG Technology DXG-503 Digital Camera
Can not down load pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jan 25, 2011 | DXG Technology DXG-503 Digital Camera
Shutter slow, pictures blur if not on solid object. Exposures OK.
This is a common problem if you are taking pictures in low light with out using the flash.
I suggest to set all settings in your menus to factory settings. Then set them the way you want. This may change some settings.
Always either have the camera on a solid surface or use a tripod when you take slow shutter pictures without the flash.
Oct 19, 2009 | DXG Technology DXG-503 Digital Camera
When DXG model 503 powers up, I switch it to camera mode & the unit shuts self down leaving lens out & open? Camera has a lexar SD 256 mb card in it, is this eoungh memory?
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 27, 2009 | DXG Technology DXG-503 Digital Camera
Used dxg-503 digital camera won't power on even w/new batteries
If this camera has a memory card, remove it and then try turning it on. Sometimes the memory cards make the cameras act different.
If there is no memory card or card is out and you have same problem, you can send it in to DXG company and they will repair it for $50
May 06, 2009 | DXG Technology DXG-503 Digital Camera
MY CAMERA WILL NOT TAKE PICTURES, HOWEVER I'M RECEIVING AN MEMORY ERROR MESSAGE
The problem usually relates to using an SD card that is too high in capacity. THE DXG 518 only supports SD cards up to 1 gig in size.
Mar 14, 2008 | DXG Technology DXG-503 Digital Camera
No file
Files can be retrieved -through your computer. If you have a card reader- built in or external or plug in or as part of an all in one, If you have none of these you can try this way. 1, go on line to www.konvar. com and download PCInspector. and install the program. Connect the camera so that the camera shows as an additional drive/camera as a drive letter [E?] Run PC inspector and direct it to 'E' and follow through setting up a save to folder during this. The images[if any] will be recovered. you may then format the card in the camera[do not format in the computer
Aug 15, 2007 | DXG Technology DXG-503 Digital Camera
DXG Technology DXG-503 Digital Camera Logo
90 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
John Anderson
John Anderson
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
