Question about Canon imageCLASS D320 All-In-One Laser Printer
Replacing toner unit
How do I open the Canon Image Class D320 printer to change the toner unit?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
    President:
  • Canon Master
  • 1,447 Answers
I have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Posted on Jun 26, 2009
  • Sazeed Computer
    Sazeed Computer Jun 26, 2009
    paper feed over turn unite
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
E100 system error alarm on cannon image class d320
related to fuser unit.try to clear it in service mode
May 25, 2011 | Canon imageCLASS D320 Digital Copier
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
Canon d320 image class makes knocking sound and nothing prints
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section
pifonski
Feb 20, 2011 | Canon imageCLASS D320 Digital Copier
Canon image D320 copier doesn't copy entire page
Dear sir,
its problem copier fuser unite
fuser cover is broken .Change it near by copier expert and then solve your problem
Aug 14, 2009 | Canon imageCLASS D320 Digital Copier
I have a D320 Image Class
dear it is problem copy emage plese setup copy exproser
or printer set up
  1. edit toner save mode off
Jul 09, 2009 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Will not copy
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon imageCLASS D320 All-In-One Laser...
Printing from my macbook pro using my Canon Image Class D320 I recently purchased a MacBook Pro and I'd like to print using my Image Class D320. I see no support and no drivers out there. Any...
I am sorry but some companies do not have Mac drivers for the older devices. You can try downloading the SWITCH ( not sure of the correct name) program that lets you run a make shift ( simulation) windows on your Mac and that may be the way to print to this device.
Jan 04, 2009 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS D320 All-In-One Laser Printer Logo
170 people viewed this question
old marine
old marine
