Ovens Logo
Susan Wilson Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does an F1 error flashing on my Dacor oven indicate?
My Dacor oven is not working, & I keep getting an F1 error. This seemed to occur right after the cleaning cycle was ran. It started beeping, the oven door would not unlock after the cycle completed, & now the oven will no longer heat up or function. It was beeping so bad we had to kick off the breaker to make it stop. Ideas?
Jorgie the appliance guy
Level 3:
Top Expert:
  • Dacor Master 5,639 Answers
  • Posted on Mar 02, 2015
Dacor Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522489
Points
32630
Sounds like an oven fuse?
5 Related Answers
SenorSushi
  • Posted on Jun 15, 2008
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
vitg55
Vitaliy Gins
  • 78 Answers
  • Posted on Dec 18, 2008
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Anonymous
  • 6784 Answers
  • Posted on Aug 01, 2009
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Anonymous
  • 744 Answers
  • Posted on Aug 14, 2009
SOURCE: F1 is displayed on Maytag Electric Oven
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
F1 code flashes
Hello & Welcome to FixYa
F1 error in your oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
1helpful
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
1helpful
We have a dacor double oven that is not running and keeps giving us error message of F1.. Neither of the ovens will work.. Any idea what is wrong and how to fix it?
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 • Dacor Ovens
3helpful
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 • Ovens
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
1helpful
2answers
F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Jun 29, 2008 • Ovens
1helpful
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 • Ovens
4helpful
2answers
Dacor error codes
12helpful
Dec 04, 2007 • Ovens
1helpful
Error codes on my Dacor Range -
Both of those codes suggest a bad membrane switch assembly. i dont specifically remember what the f1 error is, but the f0 error is "stuck membrane button" The membrane switch is just the touch panel, and usually run in the mid $200 range for the part. Its fairly easy to change, just label all your wires when you pull em off so you know what direction they go in. some of the connectors CAN BE put on backwards, so just make a good diagram or whatever to get em right. Good luck!
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
