Why doesn't my front panel of a/c is not blowing air?
I changed the original stereo to a commercial stereo and now the front panel of a/c is not blowing air anymore. Everywhere else the air blows fine, and also the defrost works well. It's only the front...
suspect a control panel issue as this HVAC (heater, ventilation, Air conditioning ) system should be all electric... If you can pull the control panel out looking at the back of it will answer your question... are the cables or just wires..
the problem is a vacumm leak , the control panel works with vacumm from engine supplied by small hoses and also have an vacumm tank under right front fender , check for disconnected hoses or break, the main vacumm hose is on engine intake manifold, ahh , also check control panel
the resister block needs changing... oddly enough i'm unsure of what fan you are saying is not working.... if it's the front.. the resister block is located on the duct work under the dash for the air... near the fan... you will see a connector going into the side of the duct work. two screws and the block comes out... should be fairly obvious for the rear one but it will be near the fan.
