Question about Maytag JMC9158AA Microwave Oven
The jcm9158aa jenn air microwave cooks fine, but the fan and light do not turn off when the microwaving is complete. In order for the fan and light to turn off, you have to open the door or turn off the circuit breaker.
  • Maytag Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
The jcm9158aa jenn air microwave cooks fine, but - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Also see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Jun 28, 2009
Jenn-Air jmc2430 built-in does not run.
Hey David... sorry to say
There's a $14 fuse between cooking & your magnetron (could be other things (but in my opinion... magnetrons sound right for your symptoms)
I checked for your magnetron
and got MFR Number 461967847321 - not AVAILABLE.
(there is one $74 on eBay (
very bottom, below)).
I LOOKED at your oven and it is a really nice one...
So I think I'd be hitting all the on-line parts houses
to see if you can locate one...
Jenn Air jmc2430 built in does not run
http://www.appliancepartspros.com/whirlpool-magnetron-461967847321-ap5987313.html
461967847321 NEW MAGNETRON WHIRLPOOL KITCHENAID MICROWAVE NON OEM WITH...
May 15, 2016 | Jenn-Air Microwave Ovens
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
Microwave makes noise after door is opened jenn air model jmv9169ba
Microwave ovens emit powerful radio waves and in general for safety reason should only be used when in perfect working order. It usually costs more to repair an older microwave oven than to simply replace it.
Suggest buy a new one.
Mar 02, 2018 | Jenn-Air JMV9169BAS Convection Microwave...
Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
Jenn Aire microwave oven combo, microwave has gone out. Will cost almost as much to have repairman check it out as it would to replace with a smaller microwave. We have not been able to find a comprable...
The fan can be the fan itself, the sensor or the controller. If you can find the right repair shop it would be worth fixing. The problem is finding that shop. Generally as you have found out it is cheaper just to replace.
Best advice I can give is just to call as many repair shops as you can and get a estimate. I know that the obvious thing but really unless you get in touch with "the right shop" they will charge too much to make it worth fixing. Most shops do the board replace routine. They will narrow it down to a board instead of replacing a 50 cent part. Thats really the problem.
Jan 24, 2011 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMV8000BAW
I always recommend that folks use the vent / hood fan anytime they're cooking with the stove.
Was it on at the time?
If not, moisture can certainly get into the works and cause problems or damage. If it dries out, it's fine but if not, it could cause damage.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 15, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Most of the LED display is inop
Give me the complete model # from the sticker inside the microwave so I can look into this for you.
Nov 15, 2007 | Jenn-Air M439 Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Maytag JMC9158AA Microwave Oven Logo
74 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
