SOURCE: GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
SOURCE: I have a GE SpacemakerXL
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using FixYa.com
SOURCE: Microwave oven (nn-sd997s) stuck in
Pressing "timer/clock" button 4 times turns on and off demo mode.
SOURCE: we had a power blackout now my panasonic genius
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
When there is no heat, but everything else seems to work, it means the magnetron circuit has failed. The magetron is the part the generates the microwaves that heat the food. When it fails, it makes a loud buzzing sound. The replacement part can cost as much as a new oven, so it not worth fixing. Get yourself a new oven.
