Question about Mitsubishi WS-65809 65" Rear Projection Television
I have a ws-65908 that won't power up. When I press the power on button, the green light at the ON button comes on then goes off 3 seconds later. Any ideas on how to fix it?
  • j_buchanan Jun 25, 2009
    The blink code is 2 then 3.
    The model is ws-65908.
  • Mitsubishi Master
  • 8,617 Answers
Have you tried to access the self diagnosis feature by holding in the menu button and the device/input button on the set for five seconds? The led should blink a series of blinks then pause briefly then blink another series of blinks for the 2nd digit let me know what the blink code is an I will assist you.
Posted on Jun 25, 2009
  • Sonny Berry
    Sonny Berry Jun 25, 2009
    Thats the error code for horizontal Deflection shutdown, Can you double check your model number to see if its the WS55809 as the WS55909 isnt in my database as a valid mitsubishi model. Double check the model number and let me know and I will assist you with the possible cause of the shutdown
  • Sonny Berry
    Shut-Down with 2-3 Code
    Main Power Supply surges at startup causing Horz Deflection to spike, triggering error code 2-3 and shutdown. Cause is defective IC Error Amp IC9A51 (SE110N) not holding down. Replaced with NTE7215. Also replaced associated photocoupler PC9A51 with TLP421.
The on/off relay does not stay engaged
Based on model number listed here:
If set powers up and green light comes on and goes out a few seconds later:
Press and hold menu and input (source) buttons at same time on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of five times.
If the set has been unplugged you will have to plug it in and turn it on letting it fail (unplugging will clear all errors).
Let me know error code and I will explain--2,2 is most common and most easy one to fix.
Jun 12, 2012 | Mitsubishi WS-65908 TV
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a WS 65908........it has the same problum--listed on this site.......power on for 3 seconds...and it said this.... Do the self test this model has: When set shuts off and on front of set power...
Error code 23 on this set means that the Horizontal Deflection circuit of the set has failed. Usually this points to a damaged Horizontal Deflection IC and sometimes the HOT(Horiziontal Output Transistor) as well, not to mention the resistors that are blown when the IC failed. Replacing these parts should resolve the problem.
PS:Note that the Deflection circuit involves certain high-voltage components and prior to repair it is advisable to discharge the high voltage before attempting the repair. You will also need to know how to use a multimeter(to test the HOT and look for blown resistors) and a soldering gun. If you think you can do it yourself, let me know and I will provide you detailed step by step instructions.
Sai.
Sep 15, 2011 | Mitsubishi WS-65908 TV
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Power on for 3 seconds then shuts off
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 29, 2010 | Mitsubishi WS-65908 TV
65 INCH-MITSUBISHI TV WS-65908 WILL NOT POWER UP
same problem with mine.. i usaually hit the reset button if it continues you need to get it service. when i called for service i stik had warranty and they replaced a capaciter.. it would of cost atleast $500. GOOD LUCK
Jan 26, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Re:problems
Your TV is probably shutting down due to excessive current draw. Replace the filter capacitor in the power supply and cross your fingers. This will be a large, tall, and round shaped object near the location where your power cord goes into the TV. It has two pins and one is positive and other is negative. Do not get them crosses when installing new part. keever
Oct 22, 2007 | Mitsubishi WS-65908 TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
281 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
