Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Talkabout 250 screen cracked
The screen cracked on our talkabout 250 and now the channels won't change. Can it be fixed?
  • Motorola Master
  • 1,654 Answers
Sorry, but the answer is no. The fact you cannot change channels indicates the damage is deeper than just the screen.
Posted on Jun 26, 2009
WHERE A CAN GET THE VOLUME KNOB FOR THE TALKABOUT 250?
Contact Get Support at Motorola Solutions for the part number. If not available direct they might have a repair shop who could provide it.
Mark
Motorola Mobility Support
Mar 03, 2015 | Motorola Talkabout 250 2 Way Frs Radios...
How can I replace batteries in motorola talkabout 250
See thoroughly your Radio and you will get the place from where you can replace the batteries or you send me pic of your radio.
Jan 19, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
The U-shaped bottom of the radio will slide down and off the radio, it will include part of the back of the radio.
Jan 04, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
I changed the batteries on my Motorola Talkabout 250 .......shows full power...both are set for the same channel and code.......but they aren't communicating. Please help.
Remove batteries from both. If there's a "factory reset" option try that. Re-check that they are REALLY on the same channel and code. Also be sure there's nothing stuck in the external headset jack.
Aug 11, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
Will talkabout 250 communicate with cb
No. Your Talkabout T250 operates on FM UHF frequencies between 460-470 MHz. The CB operates on 40 frequencies between 26-27 MHz.
Best regards.
Oct 27, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
How do you change batteries on a motorola 250 talkabout phone
The U-shaped sides are attached to the back battery door on this style radio. Grasp the U-shaped sides and pull down. The entire section will slide down and off the radio.
Best regards.
Dec 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Describe how you call someone with the motorola talkabout 250
Your question is unclear. Call them from where? Using what device?
If they have an FRS phone, set the channel and privacy code and go.
Feb 09, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
103 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
