Question about HP PSC 1210 All-In-One InkJet Printer
How do i fix my hp 1210 all in one ink error?
Getting "check printer cartridge" message even though new ink just installed. tried resetting, shifting cartridges in and out and using just black, with no luck
SOURCE:
agnelkj
  • 210 Answers
SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
taki99
  • 112 Answers
SOURCE: i just installed my 1210
HI,
DEAR TRY COPY A PRINT i mean print out not from your system jast put a paper in to your secner and copy it if the printer do it.then reinstall your software
if not then you have to repair it from your nearest printer repair shop.
Posted on Dec 14, 2008
  • 199 Answers
SOURCE: Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Posted on Feb 27, 2009
cene765
  • 787 Answers
SOURCE: Printer won't recognize ink cartridge
Try cleaning the contacts on the carriage unit with piece of cotton and alcohol.If this not help there is a problem in carriage unit and your printer need service.
Posted on Oct 23, 2009
  • 313 Answers
SOURCE: installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Posted on Mar 17, 2010
I receive hp catridge error when i refill the catridge and install in my printer.
check if cartridge is genuine
check if it is really a brand new one or fake
power cycle the printer
check if it has an alignment option,align the cartridge with new inks
check if it has a clean utility automatic cleaning
or you can manually clean the contacts on printheads which detects the inks the you inserted
reset the unit if you know how to
different printer has specific way of resetting
most probably you are just getting a rejection error try using theold one if that fixes the issue it means there must be an issue with brand new inks
hope it helps you
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
My printer doesnt print anymore error msg and will not turn off. Ive installed new print cartridges and no luck keep getting the error msg and wont print at all. I have a psc 1210 all in one
What is the error message?
Also, please consider the following:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
I just installed my 1210 all in one HP printer, its used and i havent used it in a while, it had an error message by the ink cartridge light so i had to put in new ink cartridges now it will do anything...
HI,
Dec 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer - error message
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Jul 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
Inkjet refills
hi,
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
Pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Jul 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
103 people viewed this question
Clive
Clive
Thomas F. Schneider
