Question about Nikon N65 35mm SLR Camera
Pictures didn't develope
I have had my camera for awhile and never had problems, I have been taking pictures with it and had 4 rolls of film to get developed, I took 2 in and the told me there was nothing on them, so the other 2 I took some where else to get developed they told me the same thing. The camera is acting fine. Any sugguestions what might me the problem?
    Problem Solver:
  • 18 Answers
Re: pictures didn't develope
Looks like you are not loading the film onto the take-up spool correctly.
Go back to the development store and ask them if they can give you a spool of waste film (e.g. one that got exposed to the light or something). Otherwise buy the cheapest film you can find.
Load the film in the camera. Take a few frames. Open the camera back up a bit, the film should have advanced. You will be able to tell this because there is more film on the takeup spool. The frames are also numbered nearby.
It might take you a few goes to get the film to load correctly. If no luck, maybe the file wind-on is broken and the camera needs repair.
Posted on Apr 13, 2009
0 characters
3 Points
Blank Film Developing
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Developing pictures
depending on the type of film you are using and where you are taking it could be the problem. if you are using professional film and taking it to a pharmacy to get developed, the chemicals used at these places will erase the images off the film and appear as if the film is blank.
Nov 11, 2007 | Nikon N75 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
My negatives are turning out clear.
"Clear" = no exposure, right? Two possibilities: light not getting in; or film not advancing. To check the former, take a "picture" with the camera open at the back. See the light through the lens? Yes = OK, No = there is a problem with the shutter. Most likely the film is not advancing. Here's a test. Load the camera with a roll of film and take one picture. Open the camera and see if film moved. If not, go read the manual to make sure you are loading it properly.
Jan 28, 2007 | Nikon N75 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
105 people viewed this question
Top Nikon 35mm SLR Cameras Experts
Ric Donato
Bart Pulverman
Are you a Nikon 35mm SLR Camera Expert? Answer questions, earn points and help others
