Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
I have casio exilim z600, went from windows xp to w 7 with a new PC and can not connect camera nor memory card and the machine. Casio Software disc apeears to be incompatible?
SOURCE:
  • 374 Answers
SOURCE: casio camera card error
It could be either a brand that is not supported or there could be something wrong with your card. Casio only recommends Sandisk, Toshiba and Panasonic memory cards. Try one of those brands and make sure you format it with your camera before trying to save pics to it.
Posted on Nov 26, 2007
SOURCE: My camera CASIO EXILIM EX-Z600
I have a EX-Z600 and i tried updating the firmware to a 1.03, as i did the 1.02. Doing exactly what the instructions say. Now after i placed the update in the root directory and taking the camera off the cradle i was pressing the menu button and pressed the on button to get the program update page but the camera screen would only show version 1.02 then it would turn on. Why does it do that? I have also had the problem, since i got the camera, that sometimes the camera wont turn on unless i take out the battery and put it back in, why is that? Can anybody please help me.
Posted on Nov 30, 2007
mcomijohns
  • 477 Answers
SOURCE: Casio Z600
your issue is most likey your ccd replacement ccd i charge 65.00 part and labor to fix this issue all the time.let me know if i can help.
Posted on Nov 05, 2008
Nittram
  • 34 Answers
SOURCE: the screen is black and
Are the pictures also black?
Is so the main circuit board in the camera is probably faulty. This is expensive to replace.
If the Pics are still good it could be the display has been turned to off or the lcd has been damaged and/or back light is not operating.
If you could give some answers to the above we might be able to norrow down you issue further. Please also advise exactly what model Casio you have.
Posted on Nov 16, 2008
fotomohamed
  • 321 Answers
SOURCE: Camera says memory card is locked
pin inside is stuck
Posted on Jun 18, 2009
Cannot install my casio Exilim EX Z-600 to my PC running on Windows 7 Home Premium 32 Bit
You don't need any special software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
May 26, 2011 | Casio EXILIM ZOOM EX-Z600 Digital Camera
I have a Casio Exilim EX-Z600 I used it on holiday and viewed the photos on the camera, however when I got home the camera will not power on with the SD card is in it. If I take out the SD card the camera...
get an sd card reader at walmart or any other place that has some computer stuff there like 5 to 10 dollars they plug in by usb connection and are usually much faster way to get stuff off the card.
May 20, 2011 | Casio EXILIM ZOOM EX-Z600 Digital Camera
When I switched on the camera, the screen showed me "The card is locked" I assume it's talking about the memory card...but why???? My camera is a Casio Exilim EX-Z600
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 21, 2010 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Card error with memory card
Make sure you're using an SD card, 2GB or smaller. This camera will not work with higher-capacity SDHC cards.
Jan 31, 2010 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Have casio Exilim camera model Ex-600 require
I have a casio exilim 8.1mp ex-z80 green digital camera. The casing is no longer presentable. Do you know where is the CASIO SERVICE CENTER here in the philippines, specially in davao city...
Oct 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio exilim z750 sd card unreadable
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: CF xD SD memory card/stick photo recovery
May 08, 2009 | Casio Exilim EX-Z750 Digital Camera
How to download software to casio EX-Z600 camera?
Here is the link for the manual. It's a pdf file, open the link and save the file to your computer. http://exilim.casio.com/resource/pdf/manuals/EX-Z600.pdf
Feb 16, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
I am getting a message when i switch on. the card is locked
Hi
on the memory card is a small lever that has to be pushed up or down unlocking the card
Thanks for trying anyway
Feb 05, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Exilim z600 Static on viewing screen. Sometimes won't turn on/off
More than likely, you've just got a bad camera. I've helped with several problems with P/S cameras where the screens are either noisey or records a static like image. 9 times out of 10, it's the processor. Unless the camera is new or still under extended warranty..,
Feb 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Camera won't communicate with windows XP
Remove any supplied software and let Windows do the work.
Jan 31, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
22 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
