Question about Minolta MF1600E Plain Paper Laser Fax
Problem with Minolta Fax 3800,installed new drum, but still says change drum?
  • Minolta Master
  • 6,696 Answers
Have to go into service mode to change the setting for new drum. sir did you install a new drum or the toner cartridge to different parts
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 28, 2014
3 Suggested Answers
  • 2072 Answers
SOURCE: WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Mar 14, 2008
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 21, 2016 | Minolta Office Equipment & Supplies
How do I change a Drum Cartridge in a Konica Minolta Fax 2900 / Fax 3900?
toner and drum are separate the toner attaches to the drum unit.
Jun 20, 2014 | Konica Minolta Minolta FAX3900 Digital...
CHANGE NEW DRUM MESSAGE EVEN WHEN REPLACED IT
Is the drum 3rd party? if so it may not work, Mite have a bad Drum cart is it out of the box new. Take some alcohol and clean all the metal contact on the drum unit not the drum. Then reseat it.
Apr 23, 2014 | Minolta MF1600E Plain Paper Laser Fax
After changing deveoper and drum printing output is too light and the density can't be adjusted
Sir/Mam,
First did you clear the counter for the drum and developer before replacing them second did you run the required F 8 procedure if not need to buy new drum and developer. Start over the counters are cleared in service mode then you take the image unit out, then replace the drum and developer then re-install the image unit then run the the required F 8. ENSURE FAX LINE AND NETWORK cables are removed do not want a fax or print job to come in before running the f 8.
Jan 30, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Change drum error in panasonic kx-mb1900
Dear friend , you guided about Brother printers not for Panasonic . There is no any option key on the panel of Panasonic kxmb1900 .
Dec 14, 2012 | Brother IntelliFAX 3800 Plain Paper Laser...
Brother intellifax 3800 very light print along outer sides of paper, have cleaned and has plenty of toner. does it need a new drum?
It sounds like you have a dirty corona wire. We have cleaning instructions on our web site at:
WWW.CCL-LA.COM
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 03, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
How to replace new drum for Minoltafax 2800 reset the fax after re-install the drum kit.
The instructions generally come in the drum kit box. if not here is the link to the users manual.
http://konicaminolta.ca/pdf/UserFax29003900.pdf
Hope this helps
Ed
Apr 15, 2009 | Minolta MF2800 Plain Paper Laser Fax
D C LIFE MESSAGE COMES ON
Which cartridge there are two one is toner the other is the drum which is where the toner cartridge is installed.
Feb 17, 2009 | Konica Minolta Minolta FAX3900 Digital...
Minoltafax 2800
http://www.smpcshop.com/MINOLTAFAX-2800-3800-p-1150.html
Jul 23, 2008 | Minolta MF1600E Plain Paper Laser Fax
Minolta MF1600E Plain Paper Laser Fax Logo
99 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
