Question about Kenmore 22422 Top Load Washer
Kenmor model110. 92478100 cc5152491 will not agitate and will no empty water
  • 97 Answers
Hello Friend, It is possible that the water pump has ceased or has blockage in it preventing the motor from functioning the washer. It's easy to check or replace the pump on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you can easily remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Happy to help, Tim.
Posted on Jun 25, 2009
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
Kenmor top load Washer, Wshr fills, agitates, wont spin or drain
The Lid switch is the most common problem with what you have descibed.
some of the lid switches are located in the control area and some are on the right side center lid area and their is a hole where the lid has a plastic pin that presses it.
Jan 12, 2010 | Washing Machines
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Imperial
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Nov 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 22422 Top Load Washer Logo
213 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
