Question about Microsoft Windows XP Home Edition
Disc Detector I cannot locate my disc detector on my control panel. How do I get it back?
  • margy c Jun 25, 2009
    I clicked on the plus sign by "disk drives" which changed to a minus sign and a drop down said "Samsung SP1604 N" I inserted a disc again, but it didn't do anything.
    President:
  • 1,185 Answers
Go to Control Panel
System , Hardware , Device Manager , Disk Drives
Click on the plus sign.
Posted on Jun 25, 2009
  • Tom
    Tom Jun 25, 2009
    I now assume that you are talking about a cd or a dvd not a hard disk.
    When you put a disk in your CD/DVD player does it start automatically ?
    If not Go to Start right click on Start select Explore , when the list appears on the left of the screen scroll down until you find the letter for your CD Drive (E or D is normal) put the cursor over the drive letter and right click on the mouse .
    Go to the bottom of the list and choose Properties
    When that opens you have tab called Autoplay click on that and select from the drop down list at the top what you want to play and on the list below what you want to open it with.
    If you have a DVD program such as Power DVD you can chose that to play DVDs while Media Player can be picked to play CDs
The USB Port?
The USB port on many high - end radar detector models is for sending one of or the combination of: firmware updates and databases that hold red light camera & known speed trap locations. The database type uploads are usually reserved for those devices that have internal GPS devices. Some others may allow changing settings that may not be readily accessible from the detector's user control panel.
Some USB ports are for possible later use - meaning that the use of the USB port has not yet been utilized. You should contact your detector manufacturer's web site (or customer service representative) to determine what services (if any) are available for the detector via the USB port. Be aware that some services require a one time payment or subscription.
I hope this helps and good luck. Please rate my reply.
Jan 11, 2012 | Cobra Vehicle Parts & Accessories
Where do I locate the serial number on the metal detector
It is printer on a sticker on the side of the control box..if not there now go to this site and match it up
Chadman
http://www.famoustrails.com/manuals/MD7030%20Manual.pdf
Jan 08, 2011 | Famous Trails Discriminator Ii Metal...
Fire alarm panel showing problem on 2 zones
Your smoke detectors, heat sensors or fire pull stations (depends on what is installed in your system) are located on your 4 zones. The wiring that connects these sensors to your fire control panel is supervised by an end-of-line resistor. Starting at the panel all wiring on that zone is daisy chained between each detector with the resistor being placed at the last detector. The panel looks for this resistance value at all times. If one of your detectors goes into alarm this creates a short. This is how the system recognizes an alarm state. Conversely, if there is break in the wiring the system fails to see any resistance and the panel will indicate a problem or trouble condition. The most likely cause of your 2 problems is either broken or cut wiring, ie; the system no longer sees the end-of-line resistance. If you are handy and have access to a multimeter you can measure resistance along the zone loop by disconnecting the zone wires from the panel and measuring wire resistance from each detector to the last one. Most Firelite systems use a 4.7k ohm resistor so you should see this at the zone wiring from the panel. If you don't, try removing a detector somewhere in the middle of the circuit and try again. Once you find a detector with that resistance your problem lies between that detector and the panel. It is just a matter of isolating the problem by measuring the zone resistance along different points of the zone wiring. If you are not comfortable doing this by yourself then I would suggest getting either an electrician or fire alarm tech to track down the problem. Hope this helps.
Dec 29, 2010 | FireLite 4 Zone Conventional Fire Alarm...
Every disc I put in reads 'bad disc"
In that case I would suspect that the laser head Diodes, or perhaps the Quadrant Detector is faulty in your unit.
Feb 03, 2010 | Daewoo DV-6T955B DVD Player/VCR
Cannot locate disc detector
This patch may be what you're looking for.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 25, 2009 | Microsoft Windows XP Home Edition
Wiring of smoke detector head/system
Most fire panels require a resister on the "end of the line" device. If this is the case, there should be a resister on the detector you removed. If you lost the detector, check the panel diagram. It should indicate the proper resistance needed and you can purchase a replacement at any electronics store. You now have two options, wire the resistor directly into the wire where the removed detector was located, or wire the resistor in at the new detector and disconnect or cap off the wire continuing to the old end of the line location. Check the panel diagram for proper wiring of the resister.
Apr 01, 2009 | First Alert SA302 Dual System Smoke...
Hard disk
When you are not using Windows, the operating system will reduce the swap file size (since it is not being used) and the ‘System Restore’ software is making back-ups of critical files. Also, if you have a Sound Blaster card, a piece of software called Disc Detector constantly polls the drives for new media. To disable this, you will find an icon in the Control Panel labeled Disc Detector. Also, you can disable PCHEALTH from MSCONFIG and see if that helps as well. This does not seem to affect Windows. This is a "scheduler" and does *not* turn off PC Health. The PCHealth entry in MSConfig & the Task Scheduler is *only* for data collection. "pchschd.exe" launches winmgmt.exe to collect this data if the system is idle. Quite unnecessary for the vast majority of users of Me.
May 10, 2008 | Computers & Internet
NO DISK
What are you trying to check on the laser? Do you have a 'scope? There are also several types of infrared detectors out there that work well, but a 'scope is needed to ensure that the power level output is correct. Oh yeah, there is a detector that will plug into your DMM and read out the wattage...accordianman
Nov 28, 2007 | Kenwood CD-223M 200-Disc CD Changer
Microsoft Windows XP Home Edition Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
