Question about Zebra TLP 2824 Printer
Bar code is not dark enough, can it be cleaned
Can the lp2824 zebra bar code printer be cleaned and how does one clean it.
  • 31 Answers
Turn up the darkness setting. Here is a video on how to clean a printer, it isn't the same model but the procedure on the printhead is the same. At about 50 seconds into the video it shows the printhead which is basically the same on the LP2824. http://www.racoindustries.com/thermal-label-printer-cleaning.htm
Ben
Posted on Jun 30, 2009
My Zibra LP2824 Plus flashing red and green lights, how can i fix this problem as i'm in a remote place and don't have technical service for it?
Go to this site it will explain the lights and should tell you enough to fix it
https://km.zebra.com/kb/index?page=content&id=SO8026&actp=RSS
Jul 13, 2016 | Zebra LP2824 Plus Barcode Printer - USB
I use a LP2824 with Quickbooks POS, and every day i will print something and the printer will stop halfway throught the job. The only solution i have found is reinstalling the drivers, then an hour later...
its usually clogging within the printhead, remove the roller and give it a clean, also download fresh drivers incase there is some kind of corruption within the driver you are using, . finally clean the print head by opening the lid and cleaning the upper inside of the lid. (it is black in colour)
May 18, 2011 | Zebra TLP 2824 Printer
All of the sudden my bar codes are not fully printing. Missing some lines on the bottom. Also the numbers are not printing rel clear. Have ran this label before and no problem. Now it is all bar codes.
Try cleaning the printhead, then print the zebra test print. (see user manual) or just print a solid black box 4" wide by 1" long. If you have white vertical lines through it you may need a new printhead.
If print test is good try increasing the heat/darkness setting
Nov 09, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
LP2824 Zebra printer software
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
Sep 16, 2008 | Zebra Eltron LP 2824 Thermal Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra TLP 2824 Printer Logo
353 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
