This can be complicated. You need to check the bios to see if the hard drive and dvd are being recognized by the POST and the Bios. Once into the bios check the boot order and make sure that the order of the drives is your main CD/DVD drive and then your main hard drive first.
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the...
(More)
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the abit shadow card for the PCIXP2 slot. Where can I get this?
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card...
(More)
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card reader is dead. formatted and reinstalled windows xp hone on new hdd. can now use rear usb devices but still intermittent crashes. what do you suggest. I suspect moard fault. I would rather get a new moard with better specs, and use existing, very good, hardware. What m-atx board would you recommend. Thanks in advance, Paddy.
What is the part number of the 8-pin dip on the bottom of an IBM R51 27K9926 mainboard near the...
(More)
What is the part number of the 8-pin dip on the bottom of an IBM R51 27K9926 mainboard near the printer connector? It is marked 'Q4'. The only numbers I can make out are these 3 lines: f p46?? FDS ? 69 I am trying to fix the MB, not replace it. Thanks
