Question about OKI B4250 Led Printer
Replace drum I have replaced the drum but keep getting a message telling me to replace and reset the drum. How do I reset the drum counter?
Re: replace drum
1.Power off the printer.
2.Open the top cover.
3.Press and hold the gray oval button on the operator panel below the indicator lights
4.While continuing to hold down the button, power on the printer.
5.The lights on the front panel will flash twice, then release the button.
The drum counter should now be reset. End of procedure.
Posted on Nov 20, 2007
Re: replace drum - OKI B4250 Led Printer Printers & Copiers
Great, it fixed for me :)
Posted on Nov 29, 2007
  • 284 Answers
SOURCE: reset drum
im sorry to tell you this machine does not have a drum counter reset. its a fuse the blows when a new one is in
Posted on Jan 07, 2009
0 characters
3 Points
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Drum error dr-420
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Printers & Copiers
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Printers & Copiers
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
I changed the drum and there's still a message saying order there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
Reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Jan 07, 2009 | Panasonic KX-FLB801 All-In-One Laser...
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Printers & Copiers
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Drum Service Message
Yup reset counter, must open front door and press set button then arrow to replace drum and yes, press set/ok.
Oct 20, 2007 | Brother MFC-8440 All-In-One Laser Printer
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
OKI B4250 Led Printer Logo
1,073 people viewed this question
Top OKI Printers & Copiers Experts
Level 1 Expert
Dominion Computer...
Are you an OKI Printer and Copier Expert? Answer questions, earn points and help others
