Question about U-Line Icemaker
Unit is freezing but drops water in ice reciever then freezes
  • 286 Answers
I need to know the model number you have
Posted on Jun 26, 2009
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
My maytag refrigerator will not drop ice or crush ice
Hello Jerry;
My name is Peter. I am a retired field service refrigeration technician.
I need more information. Your unit model number.
If your icemaker will not harvest the ice, the how can you get ice to your crusher?
1.) The water in your ice maker does it freeze?
2.) Does your icemaker fill with water and freeze?
Contact me. It sounds like a easy fix. goodwinpeg@aol.com or phone: 443-306-1362.
Oct 29, 2014 | Refrigerators
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker water freezes before getting to Ice maker
likely you have a bad water valve where the water goes into the fridge. The valve is not sealing all the way and the water is dripping even when it closes allowing the water to freeze up
May 17, 2012 | Frigidaire Refrigerators
Check valve
If you are asking about the valve to the left of the water pump, it is used to dump water when the unit pumps the water out of the sump to keep sediment out. If it is bad, the unit will have short freeze cycles as the the valve is leaking water out causing the float to drop prematurely and causing small cubes and short freeze cycles.
May 11, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Maytag model MSD2754FR - water tube to ice maker is freezing and causing water leakage and no ice cubes.
The reason that tube is frozen is because the water inlet valve is defective and not fully closing yet staying open a little and water is seeping through that tube and freezeing...its only a small drop but soon th enext drop freezes as well then before long a buch of little drops freezes resulting in the tube totally freezing. Replacing the water inlet valve will prevent the seeping thats the cause of it freezing up, the part number for that valve is 61005626 it could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Maytag Refrigerators
I have a bottom drawer freezer Samsung refrigerator (Model: rb217abw) that is two months old. The ice maker fills with water and I can hear the mechanism drop the water into the ice bucket causing the...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze, blocking or diverting the water.. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
U-Line Icemaker Logo
29 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
