Question about Copystar CS-1620 Copier
Top feeder will not work - grabs sheet but does not go all the way thru?
  • 143 Answers
From my experience, this sounds like there is something still jammed in the document feeder. Either a torn corner of a piece or even a paper clip/staple/pencil blocking the path. There are of coarse other reasons but this by far is the most common. Good luck.
Posted on Jun 26, 2009
Paper will not feed into the printer, not even if I help it.
Suggestion, but not the answer.... Mine has same problem. I have to feed 1 sheet at a time. If the sheet is too high or too low, it won't work. Put 1 sheet in feeder, then gently push it down until it's 3/4" below the top of the feeder tray. Any higher and it won't grab, any lower and get jam message. What a pain! Finally bought wife a new printer and use this one for 'playing' and faxes. Bob
Sep 24, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have an hp OfficeJet G85. The automatic document feeder won't work about half the time. Is there a way to clean or fix the feeder? Everything else works fine.
Depends on how the ADF is malfunctioning. If it just plain doesn't work, then you are likely looking at a control cable / connector issue.
If it grabs multiple pages at same time, or doesn't want to grab pages at all, you can try using a "cleaning sheet" available for inkjet printers. Most office supply stores will sell these. The cleaning sheet helps to clean the paper path (wheels, idlers, etc). You should also be able to pop open the ADF cover, and remove any paper debris that is present. See owners manual for this procedure though, it is easy to break the cover.
Aug 25, 2010 | Office Equipment & Supplies
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Feeder wont grab sheets
open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Oct 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Brother Intellifax 1800C-jamming issue
First, check your rollers for a small piece that may be stuck between the rollers causing the jam.
Second, make sure there is not to many sheets in your tray.
Third, make sure that you have not pushed the paper down to far in the tray this uaually makes the machine grab more than one sheet.
good luck
Jan 10, 2008 | Brother IntelliFAX 1800C All-In-One...
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Erratic operation thru top copy/fax function
I don't really want to get into this, but you sound desparate. i don't work on your model very often, so bear with me. When a sheet jams, don't just pull it out. Open the document feeder as far as you can and note where it stopped (the side tha DID NOT feed). Look for a possible obstruction or even spot of something that looks dirty or sticky. If so, remove or clean it. Look at the leading edge of the jammed sheet, see if there are any indentations that could possibly line up with a sensor flag, roller edge, etc. Last suggestion. Press down of the side of the document feeder that DID NOT feed through. If this helps, then there is a problem with the latch that holds the document feeder closed. Without seeing the unit it is difficult to diagnose correctly. Let me know one way or the other. Any observations will be helpful. Ed One more thing! Make sure the leading edges of the pages you are sending are perfectly straight and smooth. Make sure that they HAVE NOT been stapled at one time (the indentation can cause a problem)
May 31, 2007 | Canon imageCLASS D880 All-In-One Laser...
Copystar CS-1620 Copier Logo
64 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
