Question about GE Profile JGSP48 Gas Kitchen Range
WHY ARENT GE PROFILE JB988 KITCHEN RANGE TWO LEFT BURNERS NOT WORKING
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Posted on Aug 13, 2007
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
ngafm
  • 166 Answers
SOURCE: GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Posted on Sep 11, 2008
MNTECH
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
Posted on Jul 04, 2009
Cracked rangestop glass assembly replace
These can be tricky, first remove everything you can from the glass top then very carefully using two small screwdrivers like tyre levers gently go around the outside & the glass top will lift off.
Apr 17, 2014 | GE Profile JB988 Electric Kitchen Range
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
My ge profile range top and burner work bu the
try cleaning the ignition wire (spark) it works with ground
Nov 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Jan 22, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
F1 code beeping
either deffective oven sensor or deffective erc control
Apr 10, 2008 | GE Profile JB988 Electric Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGSP48 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
