Question about Garmin iQue 3600 GPS Receiver
Ique 3600 updating from r1 to r6
I cannot upgrade to any version om my ique??????
  • 233 Answers
Re: ique 3600 updating from r1 to r6
Call Garmin they are very helpfull.
You may have to go step by step, say from r1 to r3, to r5, to r6.
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Posted on Nov 05, 2007
0 characters
3 Points
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
IQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Sep 23, 2008 | Garmin iQue 3600 GPS Receiver
No syncro
I updated to SP3 and installed 3600 hotsync after upgrade. No problems.
Suggest you de-instal and re-install Garmin setup CD for 3600.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Repair center for Garmin iQue 3600
dont send your ique 3600 to raytech electr.i leaving at 5 min. from there and last week they tell me they dont repair the ique anymore they send back all there part to garmin they had to much problem with them good lock
May 25, 2008 | Garmin iQue 3600 GPS Receiver
Updating R1 on the ique
If you have r1 then you can not upgrade to the latest firmware unless you ugrade to r3 first. Search the internet for r2 and r3 upgrade or call garmin and have them send you a copy of r2 or r3.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Sep 26, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Sep 18, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
