Question about Microsoft Xbox 360 Console
My x-box don't turn on at all - Microsoft Xbox 360 Console
  • 50 Answers
The power supply unit has a light indicator..
green orange and red,
if your power supply unit shows green light, it means that there is no problem with your power supply, but try to check the power cord that is directly connected to the power port of the console
if it shows orange, it means that the power suppy unit is in standby mode, try other wall outlet
if its red, dude you have to let the power supply unit to let for a couple of hours, and if its still red you have to replace your power supply unit..
Posted on Jul 01, 2009
  • 767 Answers
First try another brick power supply just to make sure
its an external power prob, if it still fails then one of
the caps or regulator has died in the main unit.
  • 6,784 Answers
The power supply board will need to be replaced in this case. it has failed.
Posted on Jun 25, 2009
My Mercury Outboard will not turn it seems like I am not getting power to the Control Box, or the Switch Box? be cause I can take a wire straight from Battery to the red wire that goes to control box and...
I think the control box receives power directly from the battery and when the key is turned to the start position, activates the solenoid and then the starter. I have had about a dozen Mercs but don"t recall a wire from the control box to the rectifier.
May 21, 2014 | 333-3213A 3 - Switch Box Assembly
GE Microwave model # JVM1740DM1WW will not start. I have turned fuse box off, and turned on again and it still will not turn on. Also, before it went out totally, I was having trouble with the microwave...
Check for a internal bad fuse or dio inside cover....Caution...If you don\'t know what your doing get someone certified to do it. I don\'t want you hurt!
http://m.wikihow.com/Change-the-Fuse-in-a-GE-Microwave
Aug 22, 2013 | Computers & Internet
1991 dodge spirit turn signals don't flash. Do I need a new fuse? Where is box?
The bulb that shows other drivers the turn might need to be replaced.
Nov 27, 2012 | 1991 Dodge Spirit
Need the fuse box diagram for a 1997 Ford Crown Vic
Check position 2, in the passenger fuse box, 30AMP that controled the Wiper Control Module and Windshield Wiper Motor.
Feel free to contact us here or in the Services Profile (under Ford Manuals).
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 21, 2011 | Cars & Trucks
When , i turn on my heater on inside the car it blow out cold air. When I increased the temperture it still blow out cold air
First check that the blender door motor is operating.This should be a little box directly in front center of the console. When you adjust the temp control, the arm should move on the box motor.
Probably though your heater core is plugged.Do a search for don-ohio and heater core and maybe the long tryped message will come up, if you CAN do a search on this site.I'm pretty new here, and don't know the `ropes'. ha! don-ohio
Oct 19, 2011 | 2000 Mercury Sable
My 2010 grand vitra headlights and tail lights are turned on but don't work ? Ow do I fix ith
Look in your glove box for the owners manual, Check the manual for the location of the fuse box and check the head light tail light fuses.
Sep 20, 2011 | 2010 Suzuki Grand Vitara
89 wrangler yj 4 cyl manual steering does not turn short enough to left, ok to right, (maybe too far right). Hit pole front right hard enough to break leaf spring. Bought this way to repair. Is now...
it could be the axle pushed back on one side. i don't think that is it though.the steering box most of the time jumps time. if it did it will turn say 4 turns one way and like 2 turn the other way from center.change steering box it will fix the problem!
Sep 16, 2011 | 1989 Jeep Wrangler
I have a 1984 v65 1098cc-problem is turn signals'some times they work or don't.if i ride it for 10-15 miles they generaly come on.i have checked fuses' wireing harnes'+connections-replaced...
check switch take test light at switch wires going to lights prob wit tester tester should flash wit lights make sure u r lesting right wirees srry not sure on colors should be the same at light next if that tests fine try hazard switch some of those bikes the lights go through those
Aug 16, 2011 | 1984 Honda VF 1100 C
I can`t find the fuse for the dashboard lights on my 2000 jetta.
First, make sure it's not that your dimmer switch has been turned all the way down.
Check fuse 22 and 23. If they're good then you may have a bad ground somewhere. Check the board and fuse box under the battery (yes, I know - but thats where vw located it) for corrosion.
Jul 20, 2009 | 2004 Volkswagen Jetta
FANS DON`T TURN OFF
Relays are located in either the Power distribution box (by the battery) or the junction box under the dash. If that is not your solution I would try the Body Control Box which is under the fuse box under the dash. I just went through a similar problem, check out 1999 dodge caravan with headlights out and park lights on all the time. I replaced this body control box($350 at the dealer) and it took care of my problem. everything works now. Buy it from a wrecking yard it's a lot cheaper. however you will probably have to pull it out yourself.
Jul 06, 2008 | 1999 Dodge Grand Caravan
Microsoft Xbox 360 Console Logo
108 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
