Question about Cell Phones
Unable to make or receive calls using Bluetooth.
After several months of successfully using my Jabra Blue Tooth with a NOKIA T-Mobile flip phone, I can't make or receive calls using the ear-piece. It is fully charged and I can clearly hear the Switch On/Off melody - but that's all. I have double checked that my cell is in Bluetooth ''ON'' mode. Any tips? Thanks, Trish Maskell
  • 389 Answers
Try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Posted on Jul 03, 2009
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
Im trying to turn on blutooth on my nokia 5800 it is coming unable to perform bluetooth operation
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 | Cell Phones
Hi i want to turn blue tooth it dosnèt work
The software might have gone corrupt.Please get it updated from Nokia Care.
Dec 14, 2009 | Nokia N76 Cellular Phone
How do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
1. Turn on your mobile phones bluetooth function
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Bruce
Dec 07, 2009 | Motorola Mobility H505 BLUETOOTH HEADSET
Problem
reformat your phone.
May 15, 2009 | Nokia 6630 Handheld
6630bluetooth prolem
FIRST OF ALL RESTART YOUR MOBILE PHONE. THEN TURN ON YOUR BLUETOOTH CONNECTION ON YOUR PHONE. ALSO SET YOUR PHONE VISIBILITY ON FROM YOUR MOBILE BLUETOOTH MENU.
THEN TURN OFF YOUR BLUETOOTH DEVICE. NOW PRESS AND HOLD THE POWER BUTTON ON YOUR BLUETOOTH DEVICE. WHEN THE LIGHT BLINKS YOUR BLUETOOTH DEVICE IS DISCOVERABLE FOR YOUR PHONE.
NOW SEARCH FOR A BLUETOOTH DEVICE FROM YOUR MOBILE'S BLUETOOTH MENU. YOUR DEVICE WILL BE DISCOVERED BY YOUR MOBILE. NOW ADD THE BLUDTOOTH DEVICE TO YOUR MOBILE THE PASSCODE SHALL BE 0000 OR 1111.
NOW YOU CAN USE YOUR BLUETOOTH. IF STILL UNBALE TO EXCESS PLS. ASK US.
PLS. RATE MY SOLUTION.
NICE DAY
REGARDS
KETAN PATEL.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Bluetooth 350
It might be the pairing has drifted slightly. I would try repairing again. It certainly cant hurt anything.
Aug 20, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Cell Phones Logo
135 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
