Question about LG 42PC1R 42 in. Plasma HDTV
I have an LG 42 inch plasma (3yrs old). When I switch on the set it goes to standby after a second. After few seconds it turns on automatically but goes to standby again. After 4-5 "switch on - switch off" periods the TV set starts operating properly. It also happens sometimes that the equipment turns off itself during the normal operation and after a second switches on again. Should I worry about it?
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
  • 44 Answers
SOURCE: gateway 42 inch plasma p42m303 6 blinks on power supply
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 304 Answers
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
Posted on Jul 16, 2009
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
LG PLASMA 42 INCH WONT TURN ON!
Sure, you will need to replace the power supply circuit board asap. this will fix your issue.
Jun 03, 2009 | Mitsubishi WS-65513 65" Rear Projection...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PC1R 42 in. Plasma HDTV Logo
91 people viewed this question
