Question about HP Photosmart C6180 All-In-One InkJet Printer
SMALL PIECE OF PAPER IS JAMMED ON THE RIGHT SIDE UNDER THE ROLLERS WHERE I CAN'T REACH IT IS THERE ANYWAY TO GET UNDER THE INK ASSEMBLY PLATFORM WITHOUT DAMAGE TO THE PRINTER I HAVE A DEADLINE NO TIME FOR REPAIR SERVICE !!
    President:
  • 2,306 Answers
Open the back door and turn the large rollers, should force out your paper jam...good Luck!!
Posted on Jun 25, 2009
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
Paper won't go through xerox
Under rubber roller of the presenting the paper is located brake platform. Check as she works. This often can be that paper pulls not exactly. Follows to restore the brake platform. Good luck.
Oct 07, 2009 | Xerox XC356 Copier
HP Officejet 7310 AllInOne. 1.Had paper jam, carefully removed jam. (happens from time to time no prob). 2. Prob - after this latest jam, paper feeder no longer works properly. 3. When printer feeder takes...
There is idea.. Vernee decision. Every time, when аa paper stuck you its remoove most often aptly. However this trouble meets in printers HP((. Prizhimnoy roller of the presenting the paper has distorted, he came out of its place or axis of the roller or rubber roller, be brake platform cost(stand)s not exactly, this that platform that under roller. Nothing else be can not. Thank you that so have well described the fault. If you to manage most see the jaggy of the roller of the presenting the paper, you understand, there all very frail and such could happen, Else brake platform from below under spring - this spring stress in platform from below on the centre exactly or two springs then they cost(stand) in symmetry, you it is necessary пробывать press on brake platform and come to a conclusion, has she even striking on the centre. Thank you
Sep 11, 2009 | Sharp AL 1631 Copier
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cartridge jammed
EUREKA! At least the following worked for me w/ this piece of sshhhh.....
went to menu - user data - cleaning..after the "cleaning' whatever that is...it worked. I also took out the cartridges and cleaned the ink contacts. hope it works out
Jan 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Paper won't feed and get's stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
Good luck..
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jams
Nov 27, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
CX11NF "Paper Jam" and Noise
There is two sensor one paper in and paper out any one or both
Sensor not working find sensor and check it for physically working or not
Feb 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
74 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
