I apologize, but I've never seen the word "auriculars" used by Panasonic and don't really know exactly what you need help with, but I'd like to try. The dictionary says that "auriculars" means "adjective 1. of or pertaining to the ear or to the sense of hearing; aural. 2. perceived by or addressed to the ear; made in private: an auricular confession." Based on that, I wonder if you're referring to connecting an auxiliary headset. If so, there's a standard 3.5mm jack headset on the lower left side of the phone with an embossed headset symbol that can be used. If you're asking about adjusting the handset or speakerphone volume up or down, that's done with the circular silver ring in the lower right front of the phone that has up and down pointing arrows raised on it. If you're asking about hearing aid compatibility, the handset has the required magnetic transfer coil built in so as to allow a hearing aid with a standard "T" coil setting to pickup the handset audio. I hope I've helped, if not, just ask again with a little more detail and I'll try to respond.
SOURCE: My red message indicator light
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Carl
Testimonial: "Thank you!!! That solved everything!!"
SOURCE: How do I program my panasonic KX-DT343 handset to
You do that by programming the ICD groups on the phone system it's attached to.
It requires system programming access and probably a knowledge of ICD group 601.
Carl
SOURCE: need to change hold music
It depends on where the music source is coming from. A Panasonic TDx system has a port for external music located on the system cabinet. If it's enabled in programming, that's what you hear. If not, you get an internal "tune".
If the music is exterhal, all you have to do is find the box that is playing the music and change the recordings. That's a whole other topic :-)
Carl
SOURCE: We have a new Panasonic
The music is chosen at system installation. It's system programs 710, 711 and 712. Contact your Panasonic installer or dealer to get into programming.
Carl
SOURCE: i have a panasonic kx-dt343,
Normally, the ICD group is 601. So, press PROGRAM, pick a button, and dial 54601 STORE. The button becomes a log for all calls ringing into the 601 calling group.
Carl
