Question about Canon Office Equipment & Supplies
Ir 3245 slow printing on pdf files - Canon Office Equipment & Supplies
  • 4 Answers
Pdf files getting slow in ir 7200
Posted on Dec 25, 2009
  • 143 Answers
This may require a firmware update or even try printing the PDF file from a different version of Adobe.
Posted on Jun 26, 2009
  • 922 Answers
Download the latest PCL driver from Canon's website.
Install it on the the computer requesting the print, not the server.
Reboot after you install.
If that doesn't work try to find a PostScript (PS) driver.
(Adobe products were developed on PS drivers.)
If this helps please vote for my solution.
Posted on Jan 05, 2010
Canon IR 3300 PDF file slow printing
you cannot do anything with it
it also happens in my machines
Apr 05, 2014 | Canon FAX JX200 Fax / copier Plain Paper...
Hi How do I get my Canon iR2016i to automatically
You need to install a PDF printer driver on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 29, 2011 | Canon iR 2020i Laser Printer
Acribat reader ir 3300 canon printer wery slowprint what is solution
Removing and reinstalling the printer driver will fix most issues such as this.
But if you are finding its just slow for PDF files read on.
If we break down the actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling/converting the document to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
This can also help to increase just about any slow PDF printing issues as it means that a soft font does not have to be created as the file is directly converted to a graphic and then printed as such.
Lower the print resolution (this can be changed from both the Windows print settings and from the printer itself if it has a LCD type panel) If we lower the print resolution most of the time the difference is very small, but it can reduce the actual file print size of the document by up to 300%, which can greatly decrease printing times, especially if your pc or printer does not have lots of memory (RAM)
Make sure you are using the very latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat, as this will provide the most stable and efficient platform.
If the printer only has a small amount of memory if possible add more, if possible install a Post Script SI MM.
Feb 11, 2011 | Canon Ic2300N Printer
Can't print pdf
Oct 27, 2009 | Canon iR 2020i Laser Printer
How do I change the inks on my HP Deskjet F2280 please.
how I can print pdf file in ir 5000 in high speed because it gets slow
Oct 11, 2009 | HP Office Equipment & Supplies
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
Very slow PDF and large files printing
Change to print as an image.
Go to print then click on advance and select image.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Nov 09, 2007 | Canon imageRUNNER C3200 Copier
889 people viewed this question
old marine
old marine
