Question about Zyxel NSA-220 (NSA220) Network Storage Server
Can i install apps on this server
I want to add my own media sharing client on the nsa-220. i was thinking about tversity.
My samsung blue ray will not play a video from my iPod. The sound is there but no video
SEE THIS .GOD BLESS YOU
Instructions
    • 1 All of the methods described here work best on wi-fi, but can work on 3G network if your computer is available directly through the internet. Ezshare (http://www.antecea.com/) is an app that allows you to mount remote CIFS/SMB, Webdav, NFS and FTP drives. You can then browse/open or copy video files (or any files) directly from your computer through your iPhone. The nice thing about this method is that there is no new software needed on your computer if it already supports one of these protocols. It is the only method that works natively on Linux. The major downside to this method is that you need to have you video files in the native apple (mp4) format.
    • 2 Orblive (http://www.orb.com/en/orblive) is an iPhone app that requires the orb video streaming server be installed. This server then streams your media through the Orblive app. The app work pretty well and is supposed to stream live TV if you have a compatible TV tuner card on your computer. Again, the files need to be in apples native (mp4) format. The Orb server is only available on Windows and the Mac.
    • 3 Air video (http://avatron.com/apps/) is an app that also requires a video streaming server to be installed. It is very similar to the orb server except that this server can convert the video files to play on your iPhone in batch or on the fly. On the fly conversion is great for short videos, but batch conversion works best for large videos. Like the Orb server, the Air video server is only available on Windows and the Mac.
    • 4 Tversity (http://tversity.com/) is a video streaming server only application that can stream video and music to various devices. The movies play on your web browser. It supports the iPhone through the its browser interface. The application can convert the files into suitable iPhone formats, but this can take a while. Unfortunately, Tversity is only available for the windows platform.
    • 5 Dropbox (https://www.dropbox.com/) is a service that stores your files (you get up to 2GB for free) which can be accessed by various devices including your iPhone. To stream movies/music, just upload them to your dropbox and then you can watch and listen to them on your iPhone. Obviously, you have to go through the process of uploading the files as well as making sure they are acceptable iPhone formats. Dropbox is available for Mac, Linux and Windows computers.
    • 6 Finally, an honorable mention should go to the Slingbox iPhone application (http://slingmedia.com/go/iphone). It allows you to view all your media through the Slkingbox video streaming server. However, you need to have a buy a Slingbox appliance.
Oct 01, 2012 | Televison & Video
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Installed brand new western digital hard drive into nsa210. Starter utility constantly reports invalid firmware version
Had the same problem with NSA210 when attempting to install under Win 7 - 64. I was able to install using a Windows XP machine
Feb 26, 2011 | Zyxel NSA-220 (NSA220) Network Storage...
I just bought the nsa221 2 bay media server, am using a Mac and the setup disc is a PCmsi file. what do i do next?
After installing a disk and connceting the server to your network, open a web browser on your MAC and type the IP address of your server on the address bar. The beginning user name is "admin" and the password is "1234".
Feb 13, 2011 | Zyxel NSA-220 (NSA220) Network Storage...
Cant media share with laptop
The free edition of TVersity is the best software for you, it is FREE, and is easy to setup you simply "share with tversity" from the right click menu on your computer and you are set, the ps3 automatically find the media server and allows you to view the files on the ps3
http://tversity.com/download/
Oct 12, 2009 | Sony Playstation 3 (PS3) Console
I wanna use a phone line to get the internet and the music off my laptop to connect to my xbox 360...?
Phone line? As in dial up? No dice. You need, atleast, a DSL connection or faster to get Xbox live.
You can use a UPnP media server, such as TVersity to stream music from your laptop to the 360. What's cool about TVersity is that even though the music you want to play is an unsupported format for your Xbox, it will automatically transcode (make it into something the Xbox 360 can play).
If you have a broadband connection (e.g. DSL, Cable, Sat, etc.) you can have Tversity stream your favorite internet radio stream to your Xbox 360.
Download the latest Windows Media Player, Tversity or These other media servers, install, configure (TVersity is fairly easy to setup), and go look for the Tversity folder in your Music section in the NXE menu.
I wrote a how-to on setting up TVersity here if you need help setting it up.
Hope this helps,
Bill
Sep 06, 2009 | Microsoft Xbox 360 Console
My PS3 doesn't find any media servers. Even though I can browse the internet.What do I need to do to be able to read the media servers? I have a windows vista premium PC and I am new at using a computer.
I did many tests with several Media Servers and the following points had often been the Connectiong-Problem to the Media-Server.
  1. Nr. 1 - The Firewall on your PC:
    I tested a few Media-Servers and often the problem with the connection of the devices came up from the firewall (in my case ZoneAlarm).
    To Solve this i stopped the firewall, started the Media Server (e.g. TVersity or MS MediaPlayer) and then I restarted the firewall again.
    After the in 99% of the cases the firewall then asked for creating the rules for the Media-Server Software.
  2. The Router's Port / UPNP-Setting:
    Most of the Media-Servers are needing open ports for the Media-Sharing (e.g. TVersity needs an open Port 41952).
    If the port is not opened for the connection you will in the best cases have very bad Sharing-Performance but in most cases you will at fact of the Port-Problem not be able to create a connection between the devices.
    So you have to open the needed Ports at your Router.
    If you don't want to open each needed port by hand you can also (if supported by the router) activate the UPNP-Function (Universal Plug&Play). With this function enabled each device who needs a open port can open the port by itsself (But don't forget the security problem with this function - Even if it is a fine thing it is really danger).
  3. Problem: New MP3's are not shown on a connected Server:
    Often it is a good Idea to reboot your Playstation and then reconnect to the MediaServer (New MP3's and so are then refreshed).
  4. The IP-Adresses of the Devices
    You have also take to look at the Network-Adresses of the Devices (PS3 & PC). They should be in the same Net-Range (e.g. PS3: 192.168.0.55 & PC: 192.168.0.56).
    The most easy way to be sure that this is done is using the DHCP-Function of your Router. The Router then gives each Device a IP from a predefined Range.
Hopefully I could help you to solve your connection problem with one or even more of the Settings/Points above.
I wish you a nice weekend.
With kind regards,
S. Bosch
May 13, 2009 | Sony PlayStation® 3 (60 GB) Console
Hard disk failure
You will need to install a linux EX? file system driver on your pc as the NSA box is linux based
http://www.fs-driver.org/
has a goos one
May 07, 2009 | Zyxel NSA-220 (NSA220) Network Storage...
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Jan 27, 2008 | HP Compaq ProLiant ML330e Server
Zyxel NSA-220 (NSA220) Network Storage Server Logo
48 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
