Home | Sharp | AL-1642CS Copier | I have a Sharp AL- 164...
Sharp AL-1642CS Copier
Problem for Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
By amichellecas on Jun 25, 2009
I have a Sharp AL- 1642CS - initially Sharp tech suggested replacing drum - then toner - only to now suggest checking transfer wire.....which is broken. I have all this useless extra equipment now - w/ broken wire. Any option available other than sending to Sharp to repair - or buying a new copier?
Solution #1
posted on Jun 25, 2009
Not Rated)
angelus316
Rank: Wiz
Rating: 90%, 33 votes
so does that mean that you were getting blank copies and the transfer wire is broken?
Was this helpful?
Yes
No
Popular Solutions for Sharp AL-1642CS Copier
Questions and Unsolved Problems for Sharp AL-1642CS Copier
Do you recommend Sharp AL-1642CS Copier?
Answer
Answer
fellowes c220 shredder jammed-- got some of it loose- now can't see it jammed document or get... (More)
Answer
How do I edit people in the Ricoh 3260C for scanning items?
Answer
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant... (More)
Answer
adf adjustment for sharp copier AL1642cs
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1642CS Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
