Question about Hitachi Variable Frequency Drive Inverter
A CUSTOMER HAS TWO IDENTICAL MACHINES. One has a Baldor VFD and the other an older Hitachi HFC-VWS-16HF3D drive. The Hitachi drive does not seem to provide as much torque as the machine (a conveyor/husker for corn) stalls out frequently at speed. It seems to take much less to stall this machine than the other. I suspect it is a programming adjustment but we have no manual for this drive. Can we get access to the programming procedure/parameters? any suggestions which parameters to begin tinkering with?
    President:
  • 1,723 Answers
Check the current limit setting and make sure it can pull 100% motor name plate FLA (amps)
Posted on Jun 27, 2009
What is the variable frequency drive?
VFD is a device used for speed control of 3ph induction motors & automation process control
Mar 18, 2013 | Hitachi Variable Frequency Drive Inverter
Thermal overload occurs
I too am experiencing an "oc2" on my gvx1000-1.5-t unit after replacing original motor with near identical, however, relacement motor is rated for 60hz and the vfd is programmed for 50hz. but I don't have a manual nor does my machine manufacturer, so I'm trying to source a manual to alter the vfd parameters for the new motor. My original problem was a locked shaft on the original motor and caused the oc2 fault, but I bent the shaft trying to break the motor flange free and now my spare won't work either :-(. Try removing the load from your unit and see if you still get a fault, if so, you probabley have an enternal problem with the vfd. if by removing the load you don't get a fault, check for anything seized in the drive components, including the motor shaft itself(bad bearings will do it!). An amp test of your load, if it runs long enough to test, will tell you if you're exeeding the vfd's programmed full/max amp set point. Adjust the set point or remove the cause of the excessive amp pull. Good luck. Wouldn't happen to have a manual on the unit I'm looking for, would you?
Jan 23, 2011 | Inverter Bonfiglioli Gvx1000
E 21.3 FAULT DISPLAY
you didn't indicate what model number. ON a L200 for example E21 means over temperature. You need the model number
http://www.clrwtr.com/PDF/Hitachi/Hitachi-L200-VFD-Drives.pdf
For a quick reference on the L200 WHAT MODEL DO YOU HAVE? The .3 would be it's status when the fault occured. 3 means constant speed. Are you overloading the drive?
http://www.clrwtr.com/PDF/Hitachi/Hitachi-L300P-AC-Drives.pdf
This link is for a L300 for example
Sep 30, 2010 | Hitachi Electronics - Others
Any real time function is there in hitachi VFD..? VFD need to operate it certain speed based on time.
Ther are settable ramp up and ramp down times and there are settable speeds (max and run)
Mar 27, 2010 | Hitachi Variable Frequency Drive Inverter
Bouncing drive
Control problem or parameter setting is wrong. What type of control are you using, what application is it for?
Jun 23, 2009 | Speed Hitachi Variable Frequency Drive...
Hitachi VFD Wont go
Dear sir,
Please send one operation manul of
Model no. : L100-040HF6
KW : 04
HITACHI SR.NO. : 242RT18618200570204
With regards
For GROUP PHARMACEUTICALS LTD
CHANDRAMOHAN POOJARI
ASST MANAGER - MAINTENANCE
Dec 14, 2008 | Sprint Hitachi P300 Cellular Phone
Vfd sj300
vfd sj300 inverter looks like hitachi make inverter. if thats the case give me a mail for drgs.
rathaursunil@gmail.com
Nov 24, 2008 | Toshiba Electronics - Others
Hitachi Variable Frequency Drive Inverter Logo
281 people viewed this question
Top Hitachi Electronics - Others Experts
Are you a Hitachi Electronics - Other Expert? Answer questions, earn points and help others
