Question about Kenmore Washing Machines
Water level knob won't turn to select water level; stuck on small load
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Wash load Knob will not turn
Sounds like the water level switch needs replacing
http://www.whirlpoolpartsonline.com/
To get the part number - it may be available at a better price through Amazon or through a local dealer.
Apr 09, 2014 | Whirlpool Washing Machines
Water is not coming in to washing machine when Start knob is pulled. When I disconnect both hoses, water is coming through faucets. Spin cycle is working fine.
ok
Two things control the fill. The fill "solonoids " ,hot and cold, via the temp selector
and the water level switch.Check cold only. If you get cold then your problem is definitely hot solonoid or temp select switch.If you get no water of any temp
then suspect water level switch and or temp select.Water level switch is behind console.Sometimes just turning level knob will get it to work . In any case, remove console and find the large switch with the small tube attached to it. If that tube gets kinked or clogged the machine won't stop filling.Your problem is the opposite. The switch thinks the tub is full. To test the swich, pull start knob.Put a volt meter or simple test light to one side of switch and ground, Then do same test on other side of switch.
There should be voltage available on both sides .If voltage on one side. replace switch.If voltage on no sides, the problem is the timer.(Not likely)Remember ,this test there is live electricity use extreme caution please!
Hope this helps
Sep 15, 2011 | Washing Machines
My maytag top load water level knob wont budge, has difficulty turn it to select load size
that is on the pressure switch a small rocker arm it may have been turned pass the end setting
and broken or it has been exposed to water and rusted open the back to the slection switch panel see if you can lube it a drop only on the shaft make sure power is off there's 120 volts on those terminals
Jun 09, 2011 | Washing Machines
Water level control knob
Check that the knob is actually turning the shaft that it sits on..Gently turn shaft with pliers and see if fill level changes...Good luck...Nomess
May 13, 2010 | Washing Machines
Overfills
faulity water level switch {test & replace} stuck inlet valve test clean or replace . level switch is located in the control panel it will have an air tub connected to it. set vom meter on RX1 look for 0 on one infinity on others. inlet valve inside were hoses go in same setting should read 100 to1000 ohms on each
Nov 28, 2009 | Boating
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Top load washer when you start cycle no water and it starts to agitate does it on all cycles
Hi, It could be faulty timer, the knob you turn to select cycles(programs) or faulty water level switch, the knob or button you select the water temperature, or size of water level, it depends on brand of machine. check water level switch by lifting top of machine, you will see tub, look at back you will see a small tube coming from wiring harness, where controls are, that tube comes from switch to connection on side of tub, remove tube from tub connection, wipe it, put in your mouth and blow air into it, you should hear a click sound whenever you blow into it, sometimes could get stuck, connect tube back to tub, manually fill with water, just a little above half, then start machine from the beginning of any program, let it complete to the end, then try it normally to see if it does the same thing, if it does, you will need a mechanic to check timer and pressure switch. good luck.
Aug 06, 2009 | Washing Machines
My Kenmore washer does not stop filling with water when it is set at the top two settings for larger loads.
ck to be sure small hose on water level switch is secure ..does water shut off when timer knob is pushed in?if not suspect fill valve stuck open if it does shut off suspect water level switch no repair just replace
Oct 25, 2008 | Washing Machines
Kenmore 90 series top loader washer water level.
There are easy checks before you replace the level selector body
remove the trim plates at both ends of the control panel to expose Phillips head screws 1 at each end. remove the screws
lift and swing the control panel up and over the back, it is hinged at the top.
The washer can be operated in this condition for testing
1 Rremove the air hose, and blow it out.
often water remains in the tube after changing levels, the water is not compressible so a small change in water level in the tank, makes too much difference in the sensor.
reconnect the tube and try a cycle ~1/3 chance of fixing it
If fail,
2 The spring inside Kenmore water level sensors that reacts to air pressure in the tube is not up to the job and stretches, not noticeable till changing water level settings moves the anchor point of the spring.
pull off water level knob from control panel front, from control panel back depress lock tab at right of level selector body rotate counter clockwise 45 deg and remove
adjacent to selector knob shaft is 1/8inch nut, turn clockwise to raise water level counter-clockwise to lower water level, test, adjust, test adjust ~1/2chance of fixing it
If fail
replace level selector body
May 17, 2008 | Kenmore 22422 Top Load Washer
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
