Question about Kenmore 63893 Stainless Steel Top Freezer Refrigerator
Kenmore elite freezer/fridge hot to the touch on the front.
Kenmore elite freezer on the top, just defrosted the whole thing. It's running fine but super hot to the touch on the panel between the freezer and fridge. What's up with that?
    New Friend:
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Posted on Aug 30, 2013
  • 8 Answers
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
Posted on Nov 04, 2008
22yooper
  • 828 Answers
SOURCE: losing coldness in freezer and
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
Posted on Jun 10, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
philbran
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
Kenmore Elite 22.4 cu. ft. Bottom Freezer
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigerators. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Mar 09, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge feels hot to the touch between the fridge and freezer
I had similiar issues, I found that running a manual defrost cycle (Diagnostic test of the defroster) was enough to get the air flowing accrost the coils in the back of the freeer
Aug 17, 2009 | Kenmore Refrigerators
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Feb 23, 2009 | Kenmore Refrigerators
Kenore elite bottom freezer, top fridge stopped cooling
first check that you can hear a fan in the freezer..if the fan is running you have a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 63893 Stainless Steel Top Freezer Refrigerator Logo
518 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
