Question about KitchenAid Classic Series 15'' 25lbs. Right Hand Door Swing Icemaker KUIS15NRT B / S / T / W / KUIS15NRTS Black On Stainless
My KitchenAid 15" undercounter ice maker is producing very thin ice sheets that are only frozen on the perimeters (hole in the middle). Unit is loud, producing heat and struggling. Any suggestions?
  • 153 Answers
You shoould get chaeck ur processor that isnt producing enough gas
Posted on Jul 22, 2009
Why is my ice maker making too much ice?
There is ar thin metal bar that checks for the level of ice on the bucket if the bar is bent our broken it will keep making ice all day
Sep 10, 2014 | KitchenAid 15 " Stainless Steel...
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
My iceomatic ice machine is not producing ice. There is ice frozen to the grate and water is not running
Could be a bad water solenoid. Could also be because it needs to be cleaned. If there is ice stuck to the evaporator, the hot gas bypass is not working. Try cleaning the unit first.
Nov 17, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
No ice
canyou acess theice amker assy itself??
can you look intor the icemaker make sure nothings blocking ice maker from turning(ice cubed jammed in )
look into the fill tube make sure itsnot frozen
thinkin htis machin hasan electronic "eye" if so htere a trouble shoooter under the kickplate explaining the mechanism
lastly theres a white cover plate on the front of the assy. remove the cover and loook at the white gear in the center of unit. look real close at the tabsholding that gear on.MOST common causeof failure is the ice torques the main gear and those tabs snap. if htats the case , replace the ice maker assy.
Mar 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSCS250SS not producing ice
From my experience, a frozen water line coming into the icemaker indicates a bad water valve/solenoid.
The solenoid is usually located at the bottom of the rear of the unit.
The icemaker arm could be a culprit if it was detached somehow, and was really in the stop mode. But, that would not cause the ice build up in the water tube.
Jan 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not eject the ice.
I don't know if this is your problem but I had a similar problem and it was low water pressure causing the blades to freeze up. The valve on the water tubing leading to the refridgerator was not fully open and the tubing was kinked.
May 15, 2007 | KitchenAid KSRS25IL Side by Side...
KitchenAid Classic Series 15'' 25lbs. Right Hand Door Swing Icemaker KUIS15NRT B / S / T / W / KUIS15NRTS Black On Stainless Logo
239 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
