Temperature anomalies. Even after switch off and return to -18 it does it again and again.
SOURCE: FREEZER TEMPERATURE UNSTABLE
if assited check air circulation within cabinet.
check condenser if air assited, clear and clean if necessary.
failing that air probe might be dodgey
condenser fan ?
or thermal over load on compressor
SOURCE: My AEG Arctis freezer is not freezing at the
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
