Question about Baby Gear
How does the music spa work - Baby Gear
Its in a pocket !
Posted on Jun 26, 2009
I have a Sundance 850 spa that when you switch it on at mains power , runs for 5-10 sec then shuts off. Have message - - - - that comes on display panel
Had a similar problem; the heater was blown. You might want to try disconnecting heater wires (with breaker to spa OFF).
Then see if spa pumps work after turning power on.
I got an after market heater that works great; VERY hard to install while spa is full...but I did it anyway. Good luck.
Feb 22, 2016 | Pool & Spa
How to turn spa heater with Jandy PDA?
normal running is pool mode turn to spa mode then enable spa heat it should work in not need more info
Sep 22, 2015 | Jandy Pool & Spa
How do I get the heater to work
Flip the switch
Otherwise: Heater on what?
Stand alone heater on a pool?
Heater on a spa... Separate equipment or is it on a portable spa (equipment within the spa cabinet)?
If portable spa, what is Make & Model?
Nov 10, 2014 | Pool & Spa
Control panel for spa and pool and spa heaters reads "SEr". cannot turn the temp up or down. Spa will not come on.
This sounds like the spa has been put in the Standard Economy mode.
When your spa is in this mode almost nothing works as it is in a freeze protection mode.
Change the operating mode back to standard and it should work just fine in the future.
US Parts Center
Sep 24, 2013 | Hayward Pool & Spa
Er2 on cp3800,& spa conrol in spa not working causing problems w 1 relay?
disconnect spa side control at controller if same bad board if goes away replace spa side also check relay
May 17, 2012 | Pentair Compool CP3800TX Pool & Spa...
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Apr 30, 2009 | Intermatic PART - AIR SWITCH 4 FUNCTION...
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
