Question about Samsung SyncMaster 203B LCD Monitor
Grey Band and Ghosts on monitor
Our Samsung SyncMaster203B monitor has a grey band down the left side of the screen from top to bottom and all images have a 'ghost' to the right side. Monitor is approx. 2 yrs old, purchased at Costco.
  • 674 Answers
Check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Posted on Jun 25, 2009
  • Shree Panicker Aug 29, 2013
    I had exactly the same problem with my Samsung SyncMaster 940BW. I had read somewhere that poor earthing might be one of the causes of monitor problems and just switched the socket into which I was plugging my monitor. Immediately the problem went away and my screen is back to bein g crisp and clear as it always was!
Sony KDL32W4000 TV - grey band keeps appearing
I found a manual for your TV, I don't have the time to read it all but thought you might find your answer in there. http://pdf.crse.com/manuals/3298243431.pdf
I hope this helps you. Good luck and sorry I can't help you more.
Jun 17, 2012 | Sony Televison & Video
Vertical Band has appeared on my TH-42PX60B
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Feb 20, 2012 | Panasonic VIERA Televison & Video
Just replaced color wheel. When TV turned on seemed fine but then i noticed a grey/black shadow band on one side. What could be the cause?
I had a similar issue with mine from the factory. There was a grey/black shadow in the upper left. Called for repair. The guy took off the circular access panel on the left back side and there was a fingerprint on the projection lense. He cleaned it and it disappeared. Sounds the same. Maybe touched the lense replacing the color wheel?
Sep 06, 2010 | Samsung HL-R5678W 56" Television
Grey bands and shadowing
Uninstall the video driver from the Computer, restart the Computer then reinstall it. Furthermore, check for any updates for the video drivers.
You may also connect the monitor to any other normally functioning Computer to check if the lines remain there.
If it's so then the monitor requires servicing.
Nov 07, 2009 | Samsung SyncMaster 244T Monitor
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Grey band on left side of printed page.
replace toner drum or replace cartridge
Mar 19, 2008 | HP LaserJet 4 plus Printer
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
Samsung SyncMaster 203B LCD Monitor Logo
306 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
